I guess this is sort of a continuation of:
I updated from 3.5.0 to 3.5.1 (stable channel) via the upgrade GUI (both the Docker manager and Discourse) and everything seemed to go well. But once it finished I checked the upgrade GUI again (force reload of the page), and it said something about how it wasn’t running the latest image and would require a launcher rebuild for the next update. So I did that and everything again worked fine.
This isn’t really a problem per se, as I have a fairly good handle on managing Discourse via the command line. But it seemed strange that this would be required for a X.y.z minor release from the stable branch, and after successfully completing the GUI upgrade. I don’t think there were any Postgres updates for this minor point release? On this occasion I had time to SSH in and do the rebuild, but it would have been a much bigger issue if I was traveling or otherwise didn’t have access to a terminal. Just wondering if there’s a rhyme or reason to all this. Thanks!
