I tried to upgrade Discourse from Admin UI, but failed due to “Operation not permitted” error
$ cd /var/www/discourse && git fetch && git reset --hard HEAD@{upstream}
warning: unable to unlink app/assets/javascripts/admin/models/report.js: Operation not permitted
warning: unable to unlink app/assets/javascripts/discourse/templates/search/category_result.hbs: Operation not permitted
warning: unable to unlink app/assets/javascripts/discourse/templates/search/post_result.hbs: Operation not permitted
Tried looking for similar topic in this forum, but not found. So I have to create this topic. Here is the Linux account detail:
- The docker software is installed with
sudo apt-get, by kaka_root user. This user is normal user, but is “sudoer”. - The git repo discourse_docker is cloned by kaka_dev user. This user is not “sudoer”. This user can run
./launcher ssh appsuccessfully, and become root inside container after that. This user can also run./launcher rebuild appsuccessfully. - Inside container, the folder /var/www/discourse/ is under discourse user.
Platform detail:
Linux hostname 3.5.0-52-generic #79~precise1-Ubuntu SMP Fri Jul 4 21:03:49 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
I can upgrade Discourse successfully with ./launcher command. But my team want to be able to do in Admin UI.
How can I solve this?
Thanks and regards.
