Upgrades via de webinterface zijn uitgeschakeld
I did the manual upgrade via command line and my web upgrades are still disabled
First, check that you’ve waited long enough for everything to start, and that you don’t have some kind of browser cacheing getting in the way.
But, it can happen that a second rebuild will do the trick, so that’s worth a try.
I think a git pull can help too:
cd /var/discourse
git pull
./launcher rebuild app
Im on 2.9.0.beta4 so im up to date
It says I’m up to date and I already did a server restart
When you “disabled”, what does that refer to? Do you mean the buttons on the upgrade page are not clickable?
Could it be there are no upgrades to be had? :slight_smile:
As u can see im up to date
And a second rebuild hasn’t helped?
The experimental aarch64 image arch is indeed failing to automatically pull in the last image during rebuilds, it’s on my list to investigate why next week.
This should fix it
https://github.com/discourse/discourse_docker/pull/621
