Upgrading Discourse: Multiple failures
I’m trying to do the current upgrade. It has failed and I can’t access my discourse.
There’s multiple errors. All help appreciated.
# 502 Bad Gateway
nginx
Log attached.
cap.txt (58.3 KB)
I, [2024-12-19T13:12:37.802755 #1]  INFO -- : > /usr/local/bin/create_db
createdb: error: could not connect to database template1: connection to server on socket "/var/run/postgresql/.s.PGSQL.5432" failed: No such file or directory
	Is the server running locally and accepting connections on that socket?
psql: error: connection to server on socket "/var/run/postgresql/.s.PGSQL.5432" failed: No such file or directory
1353:C 19 Dec 2024 13:13:56.951 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
1353:C 19 Dec 2024 13:13:56.951 # Redis version=7.0.7, bits=64, commit=00000000, modified=0, pid=1353, just started
1353:C 19 Dec 2024 13:13:56.951 # Configuration loaded
1353:M 19 Dec 2024 13:13:56.951 * monotonic clock: POSIX clock_gettime
1353:M 19 Dec 2024 13:13:56.952 # Warning: Could not create server TCP listening socket *:6379: bind: Address already in use
1353:M 19 Dec 2024 13:13:56.952 # Failed listening on port 6379 (TCP), aborting.
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 1356 exit 1>
exec failed with the params {"cd"=>"$home", "tag"=>"migrate", "hook"=>"db_migrate", "cmd"=>["su discourse -c 'bundle exec rake db:migrate'"]}
d7e3c61c9189308cfa984b4f73baf5bece2cdb0ce5ff4034396a0440ae3d7594
Is this a standard install? Is it just one app.yml file (and not separate web_only and data containers?)
For some reason it’s unable to connect to your databases.
Standard install. Just one app.yml.
Maybe upgrade docker. What is
 docker --version
Discourse asked me to do a Docker upgrade first. I did.
I can’t check the version now because I had to revert the server to put it back in production, so all changes have been undone.
Then you have no way to debug.
What I would likely recommend is to spin up a new VM, install Discourse there, and restore a backup. When it works, put the existing site in read-only mode, backup, restore, and switch the DNS (or a static IP if you have access to such).
You can use Move a Discourse site to another VPS with rsync so that the new site has valid certs and you can have a look by hacking your local DNS to point to the new IP address.
