We have a Discourse installation built from sources in 2016 and we need to move it to a different machine. Is an upgrade to modern Discourse running in docker possible? If it isn’t I am going to try get that version working but am running into assorted problems.
Hey David, welcome to Meta ![]()
What version is the old installation running on?
If it’s a very old version, then I would recommend taking a backup, creating a new staging server following the official guide, and then restoring the backup there. If everything works as expected, then you’re all set and you can create a new production server following the same guide and then restore the backup there.
If not, please feel free to post any issues you encounter and we’ll try to help ![]()
Thanks. It’s whatever was on master when it was installed. I will try your suggestion.
# git log
commit 65e808b26d6195b8dcc75d9c51e19b09a01891a6
Author: Sam <sam.saffron@gmail.com>
Date: Tue Jan 12 15:49:05 2016 +1100
FEATURE: go to inbox after archiving a message
Wow that actually worked! Nice work guys! Will try to keep the new installation a bit more up-to-date ![]()
