Télécharger l'icône du logo
Hi all,
I noticed that the upload logo is back to this → 07 and from my experience users where finding the process easier with this one →
Let me know if it will stay as it is or might change back ?
Many thanks
The upload logo changes automatically when you add non-image file formats as authorized extensions in site settings. To change it back, you can revert the changes to the authorized extensions site setting, or use some CSS via a theme component to modify the icon.
Fair enought, i just did the authorized extensions move.
Many thanks for your help.
