When a backup is restored to a database with a different name, there is a neat little piece of code in restorer.rb that attempts to fix this.
However, this renames ALL upload filenames, not just the ones that were extracted from the archive. If the database name occurs in an S3 path (which obviously does not change), it changes it as well, causing all images to fail loading.
No - I’m talking about filenames like //discourse-cloud-file-uploads.s3.dualstack.us-west-2.amazonaws.com/standard11/uploads/DBNAME/original/1X/abcd.....jpg
So I think we’d need to exclude uploads starting with // or something like that.
We’re experiencing the pain of this quite abit while migrating local uploads to S3. Unfortunately, no amount of hacky remaps can fix this properly. What we’re currently working on at the moment is to remove/disallow upload links in Post#raw. The short upload url, , will be used as the public interface for access to uploads in raw.
Once that is done, we will only have to remap the urls in the uploads table and do a rebake of affected posts.
“only” have to do a rebake… yes, on one hand I think it’s good to get rid of the hacky remaps, on the other hand it seems like the backup/restore and migrate from/to S3 processes are getting more and more complicated and hard.
See also a number of issues in Migrate_from_s3 problems which are kind of related but they’re not all covered by your proposed solution.
I do not think so, the moves will get significantly simpler. Walk the uploads table and upload all files to new s3 bucket, rebake and you are done.
They do though become more expensive computation wise cause a rebake is required.
This is a cost I think is worth bearing given we get a correct move at the end of the process. But, we have the flexibility of still doing database replace as we do today for the cooked column and post revisions if that is how we roll, the key change in the process is that we leave posts.raw alone and then have 0% of corruption there. posts.raw and posts_uploads auto generated map will always be stable.
I think a significant improvement would be to walk the uploads table instead of posts (see the topic I linked above) and that would indeed leave the flexibility to replace in posts.cooked
I link upload:// nel markdown grezzo aiutano molto in questo. Non sono sicuro se @gerhard abbia apportato una modifica per accodare un post di ripristino completo dopo il ripristino. (Penso di sì)
Dipende. Eseguiamo una rigenerazione di tutti i post che contengono caricamenti quando le immagini ottimizzate non sono incluse nei backup (che è l’impostazione predefinita). Altrimenti ci affidiamo solo ai rimappaggi.
