Hi there guys, I just wondered why GIFs are so small when you upload them - even if you choose 100% as the size E.g
A discussion regarding uploaded animated GIFs appearing very small, specifically those larger than 4MB, was started by Jack_Vaughan. The issue was found to be caused by a regression in the image resizing process, which was affecting animated GIFs differently than non-animated GIFs.
codinghorror identified the issue and uploaded examples to demonstrate the problem. vinothkannans found the cause to be a change in the image downsizing process and provided a fix. However, codinghorror questioned the approach, suggesting that animated GIFs larger than a certain size should be rejected instead of resized.
sam explained the complexities of implementing this approach, including the need to detect animated GIFs and drive special rejection code. However, codinghorror emphasized the importance of detecting animated GIFs and potentially converting them to MP4s in the future.
A plan to remove support for animated GIF resizing, including rejecting large animated GIFs and removing support for animated avatars, was proposed by codinghorror. This would involve removing the gifsicle dependency and keeping track of animated vs non-animated GIFs in the uploads table. nbianca has since removed the gifsicle dependency in a pull request.
This looks like an error in speficically what you are choosing to upload? Can you describe it exactly, step by step, with examples?
Here is a gif that triggers the issue. When I look at its properties on my computer, its type is set to ‘image/gif’. Its size is 10.4MB. It seems that Discourse is resizing its images. I am able to upload smaller gifs that I created in the same way without any display issues.
So this is about GIFs that are normally too large to fit the upload limit, they are being auto-resized somehow? That resulting image is tiny:
50 x 29, 32kb
Perhaps this is a regression @sam? ![]()
Possibly a regression, does this happen with non animated gifs as well?
Thanks guys - I’m using http://giffox.com/ to make gifs.
Sometimes it works and sometimes not… I think you might be right about the size. Was just doing some tests
Can make it work if it’s very short.
Here is a 2.06 mb GIF
Here is a 3.47 mb GIF
Here is a 9.06 mb GIF
Yeah looks like something very bad is happening at the 4mb limit to these @sam @eviltrout. I edited the title to reflect the issue. We got to fix this, we’ve regressed.
Just wanted to confirm this is isolated to animated gifs.
I think we use Gifsicle: Command-Line Animated GIFs for resizing do my guess is that params changed
@vinothkannans can you have a quick look today
https://github.com/discourse/discourse/commit/b57d4586d713102ce939fd8d17f2ce200f290171
It’s happening since we changed the way of image downsizing. The above commit will fix this issue and the larger gifs will scale down properly.
Is this the correct fix? I don’t think we should be “downsizing” what are effectively videos? That feels like a rather extreme (and possibly very server CPU intensive) manipulation, that could ruin video (gif) quality.
I’m not sure about this. I think we should outright reject animated GIFs which are too large rather than shoehorning ourselves into the video resizing (or even better, convert to mp4) business, that is a whole other problem to attack..
Yes, it looks like a straight forward fix. I will change the current functionality.
Anyway, it looks like we’re resizing the GIF images for the last 5 years using “gifsicle” and we didn’t receive any performance issue on it. @zogstrip may know more details.
https://github.com/discourse/discourse/commit/d456460d33859a3f6890062083ace6f64aa17266
I think in this case, rejecting very specific gifs is going to add more code to our repo.
At the moment we just assume all gifs are “animated” per:
If we are going to change it so some gifs are rejected we are going to have to do format detection for animated gifs and then drive some special rejection code. This is especially complicated for images we have to optimize (due to dimensions) cause we will no longer be able to optimize animated gifs.
On the upside we get to get rid of the gifsicle dependency. On the downside our upload pipeline becomes more complex.
Personally I think @vinothkannans fix is fine and low risk, it is code we have had for 5 years and there are no huge perf issues I know about.
That said @codinghorror I would not wrestle here if you want to nuke support for animated gif resizing but it is a fairly complex change, identification is easy enough, but driving the rejection with an error message may be a bit tricky.
Your animated gif is larger than 10mb so it can not be uploaded
Your animated gif is larger than 600x400 so it can not be uploaded
Anyway your call here. My call is just to leave the fix as is and move on but if you want to kill support let us know.
Note, this removal will also require we remove support for animated avatars (an optional feature, I am not super happy we have to be honest)
Hmm, so as long as the animated GIF fits in the total upload size bucket (??), it effectively gets its .. “video” quality reduced to match.. what?
I’m super unclear what is actually happening here.
Obviously resizing height and width is totally inappropriate for a GIF.. that’s what led to the original bug above?
The history was that we were “destroying” animated gifs when we were optimizing so if you uploaded images that was to be lightboxed we would butcher it.
Internals of our code had no “detection” logic to figure out if a GIF was animated or not. The lightboxing happens after the post is committed to the database.
The fix was to make our “resize” code not butcher animated gifs and work properly with them.
The problem is that we need to redo chunks of our upload pipeline to give “special handling” for animated gifs if we are stripping support.
There are also some side effects to consider with long term rebaking of markdown if params ever change and pulling hotlinked images.
The fix of simply fixing resizing meant that we did not need to worry about this stuff.
I don’t feel we should be doing “optimization” on animated gifs at all, so I think the code needs to detect this. Adding that path would open the door for eventual gif to mp4 video conversion which we want anyway.. eventually. So I feel this is necessary work.
Just to clarify.
You would like us
gifsicle out of our docker imageWe are looking at about 1-2 weeks of fiddly work here, just confirming you want us to take it, especially since stuff is working right now.
Sure, less dependencies is better, isn’t it?
Probably OK
Simply check remote file size. If it’s too big, don’t pull. I do not care otherwise.
Yes, mostly file size will be an issue I’d expect, long before height and width dimensions really matter. (In sing-song Twilight Zone “another dimension.. the dimension of tiiiiime”) This is also why it’s so frickin’ weird to treat an image like a video. They are rather different animals!
Yes, nobody sane wants this.
We need this code path because we should eventually auto-convert GIFs to MP4s anyway. This gets us part of the way there and that’s a net positive to the world.
I removed the dependency of gifsicle in:
