משתמשים לא מצליחים להתחבר כאשר ההזמנה פגה
סיכום מבוסס בינה מלאכותית
A user reports a bug in Discourse version v2.8.0.beta1 where a user with an expired invitation cannot log in after attempting to authenticate via OAuth2, receiving an error stating the user already has an account. The issue arises because the system incorrectly detects an existing account when the user is actually new. Logs show a validation error related to the invitation. A workaround involves deleting the expired invitation. Another user confirms the issue is resolved in v2.9.0.beta1, which includes a fix for the problem. trobiyo details the reproduction steps and logs, while dan suggests the fix may have been included in a prior commit. trobiyo confirms the fix works in the newer version and provides additional context.
Hi Team,
I think I’ve found a bug (or a regression) concerning invitations for users (version v2.8.0.beta11), let me explain the steps to reproduce it:
  1. Send an invitation to the user user@company.com. (user@company.com does not exist in the forum).
  2. User does not accept the invitation, but instead logins in by going to the Log In button. (by using discourse/discourse-oauth2-basic: A basic OAuth2 plugin for use with Discourse (github.com)).
  3. Invitation expires.
  4. User cannot login anymore by getting the following pic:
Workaround
Deleting the invitation under the following window makes the trick, allowing the user to login in again without any issue:
Logs
info
ActiveRecord::RecordInvalid (Validation failed: There's no need to invite <b>user@company.com</b>, they <a href='/u/user/summary'>already have an account!</a>)
app/models/invite.rb:242:in `invalidate_for_email'
app/controllers/users/omniauth_callbacks_controller.rb:182:in `user_found'
app/controllers/users/omniauth_callbacks_controller.rb:128:in `complete_response_data'
app/controllers/users/omniauth_callbacks_controller.rb:73:in `complete'
app/controllers/application_controller.rb:387:in `block in with_resolved_locale'
app/controllers/application_controller.rb:387:in `with_resolved_locale'
lib/middleware/omniauth_bypass_middleware.rb:50:in `call'
lib/middleware/anonymous_cache.rb:354:in `call'
config/initializers/008-rack-cors.rb:25:in `call'
config/initializers/100-quiet_logger.rb:23:in `call'
config/initializers/100-silence_logger.rb:31:in `call'
lib/middleware/enforce_hostname.rb:23:in `call'
lib/middleware/request_tracker.rb:198:in `call'
backtrace
activerecord (6.1.4.1) lib/active_record/validations.rb:80:in `raise_validation_error'
activerecord (6.1.4.1) lib/active_record/validations.rb:53:in `save!'
activerecord (6.1.4.1) lib/active_record/transactions.rb:302:in `block in save!'
activerecord (6.1.4.1) lib/active_record/transactions.rb:354:in `block in with_transaction_returning_status'
activerecord (6.1.4.1) lib/active_record/connection_adapters/abstract/database_statements.rb:318:in `transaction'
activerecord (6.1.4.1) lib/active_record/transactions.rb:350:in `with_transaction_returning_status'
activerecord (6.1.4.1) lib/active_record/transactions.rb:302:in `save!'
activerecord (6.1.4.1) lib/active_record/suppressor.rb:48:in `save!'
activerecord (6.1.4.1) lib/active_record/persistence.rb:639:in `block in update!'
activerecord (6.1.4.1) lib/active_record/connection_adapters/abstract/database_statements.rb:320:in `block in transaction'
activerecord (6.1.4.1) lib/active_record/connection_adapters/abstract/transaction.rb:319:in `block in within_new_transaction'
activesupport (6.1.4.1) lib/active_support/concurrency/load_interlock_aware_monitor.rb:26:in `block (2 levels) in synchronize'
activesupport (6.1.4.1) lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `handle_interrupt'
activesupport (6.1.4.1) lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `block in synchronize'
activesupport (6.1.4.1) lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `handle_interrupt'
activesupport (6.1.4.1) lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `synchronize'
activerecord (6.1.4.1) lib/active_record/connection_adapters/abstract/transaction.rb:317:in `within_new_transaction'
activerecord (6.1.4.1) lib/active_record/connection_adapters/abstract/database_statements.rb:320:in `transaction'
activerecord (6.1.4.1) lib/active_record/persistence.rb:637:in `update!'
actionpack (6.1.4.1) lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
actionpack (6.1.4.1) lib/abstract_controller/base.rb:228:in `process_action'
actionpack (6.1.4.1) lib/action_controller/metal/rendering.rb:30:in `process_action'
actionpack (6.1.4.1) lib/abstract_controller/callbacks.rb:42:in `block in process_action'
activesupport (6.1.4.1) lib/active_support/callbacks.rb:117:in `block in run_callbacks'
i18n (1.8.11) lib/i18n.rb:314:in `with_locale'
activesupport (6.1.4.1) lib/active_support/callbacks.rb:126:in `block in run_callbacks'
activesupport (6.1.4.1) lib/active_support/callbacks.rb:137:in `run_callbacks'
actionpack (6.1.4.1) lib/abstract_controller/callbacks.rb:41:in `process_action'
actionpack (6.1.4.1) lib/action_controller/metal/rescue.rb:22:in `process_action'
actionpack (6.1.4.1) lib/action_controller/metal/instrumentation.rb:34:in `block in process_action'
activesupport (6.1.4.1) lib/active_support/notifications.rb:203:in `block in instrument'
activesupport (6.1.4.1) lib/active_support/notifications/instrumenter.rb:24:in `instrument'
activesupport (6.1.4.1) lib/active_support/notifications.rb:203:in `instrument'
actionpack (6.1.4.1) lib/action_controller/metal/instrumentation.rb:33:in `process_action'
actionpack (6.1.4.1) lib/action_controller/metal/params_wrapper.rb:249:in `process_action'
activerecord (6.1.4.1) lib/active_record/railties/controller_runtime.rb:27:in `process_action'
actionpack (6.1.4.1) lib/abstract_controller/base.rb:165:in `process'
actionview (6.1.4.1) lib/action_view/rendering.rb:39:in `process'
rack-mini-profiler (2.3.3) lib/mini_profiler/profiling_methods.rb:85:in `block in profile_method'
actionpack (6.1.4.1) lib/action_controller/metal.rb:190:in `dispatch'
actionpack (6.1.4.1) lib/action_controller/metal.rb:254:in `dispatch'
actionpack (6.1.4.1) lib/action_dispatch/routing/route_set.rb:50:in `dispatch'
actionpack (6.1.4.1) lib/action_dispatch/routing/route_set.rb:33:in `serve'
actionpack (6.1.4.1) lib/action_dispatch/journey/router.rb:50:in `block in serve'
actionpack (6.1.4.1) lib/action_dispatch/journey/router.rb:32:in `each'
actionpack (6.1.4.1) lib/action_dispatch/journey/router.rb:32:in `serve'
actionpack (6.1.4.1) lib/action_dispatch/routing/route_set.rb:842:in `call'
omniauth (1.9.1) lib/omniauth/strategy.rb:420:in `call_app!'
omniauth (1.9.1) lib/omniauth/strategy.rb:373:in `callback_phase'
omniauth-oauth2 (1.7.2) lib/omniauth/strategies/oauth2.rb:93:in `callback_phase'
omniauth (1.9.1) lib/omniauth/strategy.rb:238:in `callback_call'
omniauth (1.9.1) lib/omniauth/strategy.rb:189:in `call!'
omniauth (1.9.1) lib/omniauth/strategy.rb:169:in `call'
omniauth (1.9.1) lib/omniauth/strategy.rb:192:in `call!'
omniauth (1.9.1) lib/omniauth/builder.rb:45:in `call'
rack (2.2.3) lib/rack/tempfile_reaper.rb:15:in `call'
rack (2.2.3) lib/rack/conditional_get.rb:27:in `call'
rack (2.2.3) lib/rack/head.rb:12:in `call'
actionpack (6.1.4.1) lib/action_dispatch/http/permissions_policy.rb:22:in `call'
rack (2.2.3) lib/rack/session/abstract/id.rb:266:in `context'
rack (2.2.3) lib/rack/session/abstract/id.rb:260:in `call'
actionpack (6.1.4.1) lib/action_dispatch/middleware/cookies.rb:689:in `call'
actionpack (6.1.4.1) lib/action_dispatch/middleware/callbacks.rb:27:in `block in call'
activesupport (6.1.4.1) lib/active_support/callbacks.rb:98:in `run_callbacks'
actionpack (6.1.4.1) lib/action_dispatch/middleware/callbacks.rb:26:in `call'
actionpack (6.1.4.1) lib/action_dispatch/middleware/actionable_exceptions.rb:18:in `call'
actionpack (6.1.4.1) lib/action_dispatch/middleware/debug_exceptions.rb:29:in `call'
actionpack (6.1.4.1) lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
logster (2.10.1) lib/logster/middleware/reporter.rb:43:in `call'
railties (6.1.4.1) lib/rails/rack/logger.rb:37:in `call_app'
railties (6.1.4.1) lib/rails/rack/logger.rb:28:in `call'
actionpack (6.1.4.1) lib/action_dispatch/middleware/remote_ip.rb:81:in `call'
actionpack (6.1.4.1) lib/action_dispatch/middleware/request_id.rb:26:in `call'
rack (2.2.3) lib/rack/method_override.rb:24:in `call'
actionpack (6.1.4.1) lib/action_dispatch/middleware/executor.rb:14:in `call'
rack (2.2.3) lib/rack/sendfile.rb:110:in `call'
actionpack (6.1.4.1) lib/action_dispatch/middleware/host_authorization.rb:92:in `call'
plugins/discourse-prometheus/lib/middleware/metrics.rb:17:in `call'
rack-mini-profiler (2.3.3) lib/mini_profiler/profiler.rb:249:in `call'
message_bus (4.0.0) lib/message_bus/rack/middleware.rb:60:in `call'
railties (6.1.4.1) lib/rails/engine.rb:539:in `call'
railties (6.1.4.1) lib/rails/railtie.rb:207:in `public_send'
railties (6.1.4.1) lib/rails/railtie.rb:207:in `method_missing'
rack (2.2.3) lib/rack/urlmap.rb:74:in `block in call'
rack (2.2.3) lib/rack/urlmap.rb:58:in `each'
rack (2.2.3) lib/rack/urlmap.rb:58:in `call'
unicorn (6.1.0) lib/unicorn/http_server.rb:634:in `process_client'
unicorn (6.1.0) lib/unicorn/http_server.rb:739:in `worker_loop'
unicorn (6.1.0) lib/unicorn/http_server.rb:547:in `spawn_missing_workers'
unicorn (6.1.0) lib/unicorn/http_server.rb:143:in `start'
unicorn (6.1.0) bin/unicorn:128:in `<top (required)>'
vendor/bundle/ruby/2.7.0/bin/unicorn:25:in `loa
Cheers,
Ismael
לייק 1
Curious, is there anything in /logs when this happens?
לייק 1
Hi Sam,
Yes, I have attached in the above message the stacktrace, related to an error message in the /logs starting by:
ActiveRecord::RecordInvalid (Validation failed: There's no need to invite <b>user@company.com</b>, they <a href='/u/<user>/summary'>already have an account!</a>)
And also there is a warning message with the following:
info tab
Failed to handle exception in exception app middleware : Validation failed: There's no need to invite <b>user@company.com</b>, they <a href='/u/<user>/summary'>already have an account!</a>
backtrace
activerecord-6.1.4.1/lib/active_record/validations.rb:80:in `raise_validation_error'
activerecord-6.1.4.1/lib/active_record/validations.rb:53:in `save!'
activerecord-6.1.4.1/lib/active_record/transactions.rb:302:in `block in save!'
activerecord-6.1.4.1/lib/active_record/transactions.rb:354:in `block in with_transaction_returning_status'
activerecord-6.1.4.1/lib/active_record/connection_adapters/abstract/database_statements.rb:318:in `transaction'
activerecord-6.1.4.1/lib/active_record/transactions.rb:350:in `with_transaction_returning_status'
activerecord-6.1.4.1/lib/active_record/transactions.rb:302:in `save!'
activerecord-6.1.4.1/lib/active_record/suppressor.rb:48:in `save!'
activerecord-6.1.4.1/lib/active_record/persistence.rb:639:in `block in update!'
activerecord-6.1.4.1/lib/active_record/connection_adapters/abstract/database_statements.rb:320:in `block in transaction'
activerecord-6.1.4.1/lib/active_record/connection_adapters/abstract/transaction.rb:319:in `block in within_new_transaction'
activesupport-6.1.4.1/lib/active_support/concurrency/load_interlock_aware_monitor.rb:26:in `block (2 levels) in synchronize'
activesupport-6.1.4.1/lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `handle_interrupt'
activesupport-6.1.4.1/lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `block in synchronize'
activesupport-6.1.4.1/lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `handle_interrupt'
activesupport-6.1.4.1/lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `synchronize'
activerecord-6.1.4.1/lib/active_record/connection_adapters/abstract/transaction.rb:317:in `within_new_transaction'
activerecord-6.1.4.1/lib/active_record/connection_adapters/abstract/database_statements.rb:320:in `transaction'
activerecord-6.1.4.1/lib/active_record/persistence.rb:637:in `update!'
/discourse/app/models/invite.rb:242:in `invalidate_for_email'
/discourse/app/controllers/users/omniauth_callbacks_controller.rb:182:in `user_found'
/discourse/app/controllers/users/omniauth_callbacks_controller.rb:128:in `complete_response_data'
/discourse/app/controllers/users/omniauth_callbacks_controller.rb:73:in `complete'
actionpack-6.1.4.1/lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
actionpack-6.1.4.1/lib/abstract_controller/base.rb:228:in `process_action'
actionpack-6.1.4.1/lib/action_controller/metal/rendering.rb:30:in `process_action'
actionpack-6.1.4.1/lib/abstract_controller/callbacks.rb:42:in `block in process_action'
activesupport-6.1.4.1/lib/active_support/callbacks.rb:117:in `block in run_callbacks'
/discourse/app/controllers/application_controller.rb:387:in `block in with_resolved_locale'
i18n-1.8.11/lib/i18n.rb:314:in `with_locale'
/discourse/app/controllers/application_controller.rb:387:in `with_resolved_locale'
activesupport-6.1.4.1/lib/active_support/callbacks.rb:126:in `block in run_callbacks'
activesupport-6.1.4.1/lib/active_support/callbacks.rb:137:in `run_callbacks'
actionpack-6.1.4.1/lib/abstract_controller/callbacks.rb:41:in `process_action'
actionpack-6.1.4.1/lib/action_controller/metal/rescue.rb:22:in `process_action'
actionpack-6.1.4.1/lib/action_controller/metal/instrumentation.rb:34:in `block in process_action'
activesupport-6.1.4.1/lib/active_support/notifications.rb:203:in `block in instrument'
activesupport-6.1.4.1/lib/active_support/notifications/instrumenter.rb:24:in `instrument'
activesupport-6.1.4.1/lib/active_support/notifications.rb:203:in `instrument'
actionpack-6.1.4.1/lib/action_controller/metal/instrumentation.rb:33:in `process_action'
actionpack-6.1.4.1/lib/action_controller/metal/params_wrapper.rb:249:in `process_action'
activerecord-6.1.4.1/lib/active_record/railties/controller_runtime.rb:27:in `process_action'
actionpack-6.1.4.1/lib/abstract_controller/base.rb:165:in `process'
actionview-6.1.4.1/lib/action_view/rendering.rb:39:in `process'
rack-mini-profiler-2.3.3/lib/mini_profiler/profiling_methods.rb:85:in `block in profile_method'
actionpack-6.1.4.1/lib/action_controller/metal.rb:190:in `dispatch'
actionpack-6.1.4.1/lib/action_controller/metal.rb:254:in `dispatch'
actionpack-6.1.4.1/lib/action_dispatch/routing/route_set.rb:50:in `dispatch'
actionpack-6.1.4.1/lib/action_dispatch/routing/route_set.rb:33:in `serve'
actionpack-6.1.4.1/lib/action_dispatch/journey/router.rb:50:in `block in serve'
actionpack-6.1.4.1/lib/action_dispatch/journey/router.rb:32:in `each'
actionpack-6.1.4.1/lib/action_dispatch/journey/router.rb:32:in `serve'
actionpack-6.1.4.1/lib/action_dispatch/routing/route_set.rb:842:in `call'
omniauth-1.9.1/lib/omniauth/strategy.rb:420:in `call_app!'
omniauth-1.9.1/lib/omniauth/strategy.rb:373:in `callback_phase'
omniauth-oauth2-1.7.2/lib/omniauth/strategies/oauth2.rb:93:in `callback_phase'
omniauth-1.9.1/lib/omniauth/strategy.rb:238:in `callback_call'
omniauth-1.9.1/lib/omniauth/strategy.rb:189:in `call!'
omniauth-1.9.1/lib/omniauth/strategy.rb:169:in `call'
omniauth-1.9.1/lib/omniauth/strategy.rb:192:in `call!'
omniauth-1.9.1/lib/omniauth/builder.rb:45:in `call'
/discourse/lib/middleware/omniauth_bypass_middleware.rb:50:in `call'
rack-2.2.3/lib/rack/tempfile_reaper.rb:15:in `call'
rack-2.2.3/lib/rack/conditional_get.rb:27:in `call'
rack-2.2.3/lib/rack/head.rb:12:in `call'
actionpack-6.1.4.1/lib/action_dispatch/http/permissions_policy.rb:22:in `call'
/discourse/lib/content_security_policy/middleware.rb:12:in `call'
/discourse/lib/middleware/anonymous_cache.rb:354:in `call'
/discourse/config/initializers/008-rack-cors.rb:25:in `call'
rack-2.2.3/lib/rack/session/abstract/id.rb:266:in `context'
rack-2.2.3/lib/rack/session/abstract/id.rb:260:in `call'
actionpack-6.1.4.1/lib/action_dispatch/middleware/cookies.rb:689:in `call'
actionpack-6.1.4.1/lib/action_dispatch/middleware/callbacks.rb:27:in `block in call'
activesupport-6.1.4.1/lib/active_support/callbacks.rb:98:in `run_callbacks'
actionpack-6.1.4.1/lib/action_dispatch/middleware/callbacks.rb:26:in `call'
actionpack-6.1.4.1/lib/action_dispatch/middleware/actionable_exceptions.rb:18:in `call'
actionpack-6.1.4.1/lib/action_dispatch/middleware/debug_exceptions.rb:29:in `call'
actionpack-6.1.4.1/lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
logster-2.10.1/lib/logster/middleware/reporter.rb:43:in `call'
railties-6.1.4.1/lib/rails/rack/logger.rb:37:in `call_app'
railties-6.1.4.1/lib/rails/rack/logger.rb:28:in `call'
/discourse/config/initializers/100-quiet_logger.rb:23:in `call'
/discourse/config/initializers/100-silence_logger.rb:31:in `call'
actionpack-6.1.4.1/lib/action_dispatch/middleware/remote_ip.rb:81:in `call'
actionpack-6.1.4.1/lib/action_dispatch/middleware/request_id.rb:26:in `call'
/discourse/lib/middleware/enforce_hostname.rb:23:in `call'
rack-2.2.3/lib/rack/method_override.rb:24:in `call'
actionpack-6.1.4.1/lib/action_dispatch/middleware/executor.rb:14:in `call'
rack-2.2.3/lib/rack/sendfile.rb:110:in `call'
actionpack-6.1.4.1/lib/action_dispatch/middleware/host_authorization.rb:92:in `call'
/discourse/plugins/discourse-prometheus/lib/middleware/metrics.rb:17:in `call'
rack-mini-profiler-2.3.3/lib/mini_profiler/profiler.rb:249:in `call'
message_bus-4.0.0/lib/message_bus/rack/middleware.rb:60:in `call'
/discourse/lib/middleware/request_tracker.rb:198:in `call'
railties-6.1.4.1/lib/rails/engine.rb:539:in `call'
railties-6.1.4.1/lib/rails/railtie.rb:207:in `public_send'
railties-6.1.4.1/lib/rails/railtie.rb:207:in `method_missing'
rack-2.2.3/lib/rack/urlmap.rb:74:in `block in call'
rack-2.2.3/lib/rack/urlmap.rb:58:in `each'
rack-2.2.3/lib/rack/urlmap.rb:58:in `call'
unicorn-6.1.0/lib/unicorn/http_server.rb:634:in `process_client'
unicorn-6.1.0/lib/unicorn/http_server.rb:739:in `worker_loop'
unicorn-6.1.0/lib/unicorn/http_server.rb:547:in `spawn_missing_workers'
unicorn-6.1.0/lib/unicorn/http_server.rb:143:in `start'
unicorn-6.1.0/bin/unicorn:128:in `<top (required)>'
/discourse/vendor/bundle/ruby/2.7.0/bin/unicorn:25:in `load'
/discourse/vendor/bundle/ruby/2.7.0/bin/unicorn:25:in `<main>'
Cheers,
Ismael
2 לייקים
I tried to reproduce this bug, but had no success. It could be either because it is some detail I am missing or this was already fixed by this commit:
https://github.com/discourse/discourse/commit/820564826e99791b1dae361f3efb6106146d4bd0
When did you last update?
3 לייקים
Good catch, in our case we have upgraded a bit earlier ( FIX: Selected group cleared between emoji uploads (#15581) · discourse/discourse@48f70dc · GitHub), 7 days before the potential fix.
Can confirm it on Monday morning anyhow since we will deploy the new v2.9.0.beta1 version by then.
Many thanks for looking into it,
Ismael
Note for the future, to attach both the version and the targeted commit when reporting a bug.
3 לייקים
So, confirmed it works properly on version v2.9.0.beta1 commit Only block domains at the final destination (#15689) · discourse/discourse@aac9f43 (github.com), several commits after the potential fix.
For information, a non-existing user with a expired invitation could login in without any problem, triggering the creation of the user account as expected.
Many thanks for looking into this and for the fix!
Cheers,
Ismael
2 לייקים
