How can I set a gamified workflow where the user has to go through a predefined KYC check to make sure that he/she is not a troll and has the following options:
Either choose to have a genuine profile with all the minimum required Biodata, if so then benefit from the gamified scores (like a verified check icon like Twitter and extra scores ) or;
Stay anonymous but be ready to not benefit from certain privileges.
So far I am still stuck at the Webhook level, any ideas for me
You could use the Custom Wizard Plugin 🧙 to build the checks and then add the user to a group at the end.
You can then make the benefits available to members of that group.
The Custom Wizard plugin does provide a 1st level check however in our use case, integration with a neutral 3rd party KYC service would have been the ideal workflow showing our audience that we have interference in the KYC. For example integration with platforms like https://sumsub.com or similar. Any idea which feature or API integration can be used here.
