لقد توقفت عند هذه النقطة بعد التحديث إلى أحدث إصدار وكان الموقع معطلاً، لذا قمت بتسجيل الدخول عبر SSH إلى الطرفية وأعدت بناء التطبيق وفقًا للاقتراح المقدم من شخص ما في هذا المنتدى، لكنني الآن عالق هنا
[2022-03-25T16:54:48.178720 #1] INFO -- : cd /var/www/discourse & su discourse -c 'bundle exec rake themes:update assets:precompile'
- Building
- Building
- building...
103:M 25 Mar 2022 16:59:45.063 * 100 changes in 300 seconds. Saving...
103:M 25 Mar 2022 16:59:45.067 * Background saving started by pid 1039
1039:C 25 Mar 2022 16:59:46.486 * DB saved on disk
1039:C 25 Mar 2022 16:59:46.488 * RDB: 0 MB of memory used by copy-on-write
103:M 25 Mar 2022 16:59:46.572 * Background saving terminated with success
2022-03-25 17:12:31.465 UTC [1071] LOG: using stale statistics instead of current ones because stats collector is not responding
2022-03-25 17:12:32.693 UTC [49] LOG: using stale statistics instead of current ones because stats collector is not responding
2022-03-25 17:12:51.921 UTC [49] LOG: using stale statistics instead of current ones because stats collector is not responding
2022-03-25 17:12:52.743 UTC [1072] LOG: using stale statistics instead of current ones because stats collector is not responding
2022-03-25 17:13:11.927 UTC [49] LOG: using stale statistics instead of current ones because stats collector is not responding
2022-03-25 17:13:22.051 UTC [49] LOG: using stale statistics instead of current ones because stats collector is not responding
2022-03-25 17:13:28.279 UTC [1073] LOG: using stale statistics instead of current ones because stats collector is not responding
2022-03-25 17:14:03.057 UTC [1074] LOG: using stale statistics instead of current ones because stats collector is not responding
2022-03-25 17:14:12.206 UTC [49] LOG: using stale stat 2022-03-25 17:41:20.824 UTC [49] LOG: using stale statistics instead of current ones because stats collector is not responding
2022-03-25 17:43:19.064 UTC [49] LOG: using stale statistics instead of current ones because stats collector is not responding
أنا لا أعرف شيئًا عن مجمع الإحصائيات هذا، أرجو المساعدة
