UX iPhone 문제
I’m facing a few UX issues with Discourse, and Iphone Chrome and Discourse Hub App.
App on iOS:
Chrome on iOS
Safari on iOS works fine
Is this a CSS or app problem?
1개의 좋아요
What component is rendering that discord button?
These are the components I’m using, but not sure which one could be the one doing that. I will have to investigate.
The main problem here is about new topic posting. App and Chrome don’t work well when it’s more text-dense — the keyboard cannot be hidden, and it’s not possible to scroll up or down the page, consequently cannot save the post.
Ah I think you are using material design theme. Don’t use this with hub. The floating new topic button on that theme is hidden by the additional hub ui. I suspect this theme was designed before the hub was created. Use another theme or fork it and modify the height of the button in CSS.
I think you meant Discourse not Discord? That was confusing.
Hi Robert, It’s just a typo mistake. I already corrected my first post.
I’m using Clean Theme, and it is already forked. I will need to investigate a way to set the button to keep the above keyboard. If you have any suggestions…
Take a look at the CSS in Discourse Chatbot which solved that issue.
1개의 좋아요
