Barra de rolagem vertical no popup de informações da resposta ao e-mail deve ser visível sem necessidade de rolagem horizontal
Hi.
When someone replies to a post by email, there is a small icon on the top right of his message.
When you click on it, as an admin, you have a popup with various email data.
The content is vertically scrollable, but the vertical scrollbar is hidden, which confused me at first.
I had to first scroll horizontally to make the horizontal scrollbar appear.
I think both scrollbars should be visible by default (if needed), but you shouldn’t use a scrollbar in order to make another scrollbar appear.
2 curtidas
I’ve seen this problem on a few email newsletters I receive (not Discourse). The width of the newsletters is much too wide - even for my laptop. Some changes to css or other code to reduce the width should do the trick… but that’s out of my league. :wink:
1 curtida
