I’ve noticed it’s possible to do this:
Create a topic in Category A
Schedule the topic to get published to Category B the next day
Edit the topic’s category to Category B
At the bottom of the topic it will say “This topic will be published in #Category B in 24 hours” even though the topic is already in that category.
Same thing for this flow:
Create a topic in Category B
I think it would make more sense to either:
warn when the scheduled category coincides with the new category (flow 1) or with the current category (flow 2), or
remove the schedule notice (in flow 1) or not allow the schedule to get saved (in flow 2)
It’s a bit of a self-inflicted wound, but I certainly agree we should show a warning in this case if it’s not too much work… can you estimate the effort next week @eviltrout ?
eviltrout
(Robin Ward)
February 16, 2021, 3:54pm
3
We could show a warning if the categories are the same quite easily. I would estimate just a couple hours of work. Can you take a look @riking ?
riking
(Kane York)
February 18, 2021, 10:35pm
5
Looks like @dan already fixed this for the shared drafts case:
committed 05:20PM - 14 Jan 21 UTC
It used to change the category of the topic, instead of the destination
categor… y (topic.category_id instead of topic.shared_draft.category_id).
The shared drafts controls were displayed only if the current category
matched the 'shared drafts category', which was not true for shared
drafts that had their categories changed (affected by the previous bug).
That model is probably what I should copy here - make the category edit save into the scheduled action.
