Avvisi sull'aggiornamento a 2.9.0.beta1
Qualcuno di questi è motivo di preoccupazione? Penso di averne visti alcuni prima e sospetto che la risposta sia No, anche se sarebbe bello sentirlo :slight_smile: Grazie.
103:M 10 Feb 2022 14:23:47.564 # WARNING overcommit_memory is set to 0! Background save may fail under low memory condition. To fix this issue add 'vm.overcommit_memory = 1' to /etc/sysctl.conf and then reboot or run the command 'sysctl vm.overcommit_memory=1' for this to take effect.
131:M 10 Feb 2022 14:23:57.845 # Warning: Could not create server TCP listening socket *:6379: bind: Address already in use
I, [2022-02-10T14:25:16.626751 #1]  INFO -- : cd /var/www/discourse & [ ! -d 'node_modules' ] || su discourse -c 'yarn install --production && yarn cache clean'
warning Resolution field "lodash@4.17.21" is incompatible with requested version "lodash@4.17.15"
warning " > @mixer/parallel-prettier@2.0.1" has unmet peer dependency "prettier@^2.0.0".
I, [2022-02-10T14:26:46.311554 #1]  INFO -- : yarn install v1.22.17
W, [2022-02-10T14:27:19.491563 #1167]  WARN -- : Removed sourceMappingURL comment for missing asset '/popper.js.map' from /var/www/discourse/vendor/assets/javascripts/popper.js
[WARN] (broccoli-terser-sourcemap) Minifying "assets/discourse.js" took: 22025ms (more than 20,000ms)
[WARN] (broccoli-terser-sourcemap) "chunk.0.b5c6b3de0b67131d0851.js.map;", "chunk.2.bf34ae0559b62d8d3c24.js.map//#" referenced in "assets/vendor.js" could not be found
WARNING: Node v16.13.2 is not tested against Ember CLI on your platform. We recommend that you use the most-recent "Active LTS" version of Node.js. See https://git.io/v7S5n for details.
DEPRECATION: The integration of jQuery into Ember has been deprecated and will be removed with Ember 4.0. You can either opt-out of using jQuery, or install the `@ember/jquery` addon to provide the jQuery integration. Please consult the deprecation guide for further details: https://emberjs.com/deprecations/v3.x#toc_jquery-apis
Solo questo è leggermente preoccupante, ma se tutto funziona, allora lo ignorerei.
Tutti gli altri sono innocui.
Ma… ma… Node v16 è la versione “Active LTS” di Node.
Grazie per la rapida risposta! Non sono nella posizione di verificare se tutto funzioni :slight_smile: Cosa cercheresti come minimo, solo che il forum appaia normalmente sullo schermo?
Proverei almeno ad accedere, caricare un’immagine e inviare un’email.
Quelle cose funzionano. Grazie :slight_smile:
Noto che in entrambe le mie installazioni (entrambe hanno solo 1G di RAM e 2G di swap) ho in qualche momento seguito quel consiglio e impostato vm.overcommit_memory=1 in /etc/sysctl.conf.
