when I upload a file(UTF8) with Chinese character, it were garbled . is this a Bug?
My Discourse version is : 2.3.0.beta3
Just confirming this is working fine if you use the UX, but has trouble when you upload a file?
from the following code, it seems only file encoded with ISO-8859-1 is supported to be uploaded.
Scheduler::Defer.later("Upload watched words") do
begin
File.open(file.tempfile, encoding: "ISO-8859-1").each_line do |line|
WatchedWord.create_or_update_word(word: line, action_key: action_key) unless line.empty?
data = { url: '/ok' }
rescue => e
data = failed_json.merge(errors: [e.message])
MessageBus.publish("/uploads/csv", data.as_json, client_ids: [params[:client_id]])
render json: success_json
@neil, do you remember why you enforced that encoding?
Hmm no I don’t. Probably copy-pasted from somewhere else.
UTF-8 would be a more common encoding.
Fixed:
@Kevin_Sun Can you update to the latest version and try again? You should now be able to import watched words with Chinese characters.
@zogstrip yes, after upgrade to latest, it works, thank you so much
This topic was automatically closed after 33 hours. New replies are no longer allowed.
