Configure webhooks that trigger on Discourse events to integrate with external services
A webhook is a way to notify external services about changes on the internet. It’s easier to setup, manage and develop than a Discourse plugin. Though, it does require you to program a little bit or understand its technical details.
In this howto, I’ll set up webhook to power a Github bot for referencing pull request brought in a forum. We’ll want to see a new comment on Github pull request when a new post has a link to it.
It’s a very simple process:
  1. Publish a new post.
  2. A webhook event happens, the payload about the new post is sent to the bot on Heroku.
  3. The bot on heroku parses the payload and check Github for existing comments. Then it creates comment when it feels appropriate.
Setting up the webhook
First, we need a webhook to feed our Github bot. Navigate to your site’s Admin section, then search for webhooks in the sidebar search. Select the + Add Webhook button to start creating a new webhook:
A webhook will simply POST the payload to the given url. https is strongly recommended. A webhook event may contain sensitive information, for example a reply to message. It may reveal information only available to staff since the payload is generated by the system user. You must fully trust this URL. Here we take a Heroku app as an example.
There are two content types available, application/json and application/x-www-form-urlencoded. We prefer json encoding.
The secret is an optional secret key for generating a signature for a given webhook event. It’s shared among you and the URL you’ve set. Once added, there will be a X-Discourse-Event-Signature in the HTTP header. It’s computed by sha256. It’s strongly recommended to set one up and verify as described below.
For this example, we only make use of a Post Event. With the Select individual events option, you can choose any events types you need. Alternatively, you can choose the Send me everything option to receive every event, even the event types that are added in the future (located at the end of the individual event list).
Triggered categories, tags, and groups are optional advanced features which allow you to filter certain events. For example, if you only care about the Staff category, you can set it so that only topic events from that category will be emitted.
Checking TLS certificate is reccomended to avoid network attacks and to keep your information secure. Be sure to mark the webhook as active and then select the Create button!
Monitoring the webhook
Click Go to events or click status information on the left side of webhook list.
With your webhook created, you will find it listed on the main webhook page. Here you can see latest delivery status (Inactive, Disabled, Successful or Failed). There are also options to edit or delete the webhook. Selecting the status or choosing the vertical dot menu’s “Events” option will take you to the list of emitted events:
On the events page, you can see various of statistics, review request and response logs (includes headers / payload / body), or attempt to redeliver individual or all failed events.
Ping is a special button to send an empty event (with no actual payload). It can help you to test your configuration. You should check out your service’s log to see if you receive a ping event.
Setting up a Github bot
We want to have a service to notify every mentions to the pull request. We’ll achieve that by hosting a bot on Heroku. It receives webhook event from a Discourse instance and processes accordingly.
The code is available here. Simply publish this to a Heroku dyno. Then you’ll need to set up some config envs in the setting page. Check out the readme of that repo.
Try it by a reply!
We’ll just need an url to the pull request.
Nailed it!
Verify and parse webhook event
Let’s dive in how it works so you can build yourself one. The flow is simple.
  1. Check out X-Discourse-Event-Id and X-Discourse-Event-Type to see whether you are interested. X-Discourse-Event also shows the internal event hook.
  2. Get payload by reading Content-Length and Content-Type.
  3. Compute sha256 HMAC of raw payload.
To be noted, X-Discourse-Event-Signature consists of sha256= and hmac of raw payload.
Webhook event type explanation
The event type is a big category of several DiscourseEvent under the hood.
Topic event
Can be restricted by categories.
Event: topic_created, topic_destroyed, topic_recovered.
Post event
Event: post_created, post_destroyed, post_recovered, validate_post.
User event
Event: user_created, user_approved.
Webhook usages
As you can see, webhook is simply a standard and configured way to notify external services. If you are looking for some kind of extension to Discourse based on changes (events) on the forum, consider webhooks. It will surely help you with a loosely coupled system. And it will be much more stable to maintain.
Last Reviewed by @tshenry on 2025-04-26T03:00:00Z
Webhooks feedback
Webhooks - documentation?
Webhook for Discourse events
Wiki sync plugin
Information about webhooks
Webhooks feedback
Webhook requests events data, where is it saved, and how to switch the logging off?
Integration Discourse <> JIRA/Zendesk
Add new webhooks and customize webhook payload
How can I directly edit Discourse database from a GUI?
MessageBus - How to setup Messagebus using Dart-Flutter
Can a plugin add a webhook?
Can we integrate discourse to CRM tool to capture leads?
Administrators Index
Is it possible to add extra API call on registration?
Mod approval to edit Full Name, or log/track Full Name changes?
About "Create New Account" button and tracking Sign Ups
2020: The Year in Review
How to get mentions for a specific user via the API?
Notifying my support team when a new post/topic is created
Discourse to Wordpress
Creating bot on discourse
Trigger a Zapier task with Discourse Webhooks
Webhook event `post_type`
Is there an API endpoint for recently edited posts
I have created webhook but after event happen I am getting Error in Response of event
Webhooks plugin
API / Functionality required to push Data from Discourse to external resource
Automated weekly messages to users?
Is it possible to set a default notification schedule for new users?
Nutzung von Nextcloud aus Discourse heraus
Discourse Automation
Passing back variables to Survey Gizmo
Discourse 部署成功后如何接入小程序、APP?
Reply to topics in a specific category
Shopify Integration
Creating Network Graphs
Detect if a topic has a new post
Webhooks feedback
Paginating API search results
Create a Salesforce lead via Zapier when a user signs up on Discourse
Best way to nudge users who havent completed signup
How can I insert users details in to CRM as soon as user signup on discourse
Integrate OAuth with an invite only flow
Event when a tag is removed from the topic
2018: The Year in Review
Deleting user - notification if they re-join
Is there a support about api check when users create topic
What is the difference between revised and updated with the Topic Events?
Neither updated nor revised seem to fire on a post edit - perhaps I misunderstand the intent.
What I really want is for the webhook to fire when (and only when) a specified tag is added to the topic. Is this doable?
It would also be great to have more detail on this in the wiki above, as the functionality seems to have expanded quite a bit since it was last updated.
Is there any way to trigger a webhook on other events? Like ‘user xxx bookmarked a post?’
Is it possible to write our own webhook triggers ? I looked around couldn’t find anything similar.
