Webhook's Group User Event doesn't function
Hello,
I’m trying to make an integration with Make.com using the custom Webhooks. It seems that the Group User Event isn’t functioning well when I’ll use Triggered Groups. When I leave it blank, it will work.
The reason I want it to be specific is so that I can save from the “Operations” from Make.com when it’s triggering a Webhook.
