The discussion revolves around automating the process of welcoming new members on Mondays. alefattorini describes their current workflow using a spreadsheet and Linux shell commands to generate a list of new members, and asks if Discourse can offer a similar feature to Facebook groups. pfaffman suggests using the Data Explorer plugin and shell commands for data extraction. codinghorror mentions Discobot and the ‘New User of the Month’ badge as existing tools. mikechristopher proposes using webhooks and Zapier to automate the process by syncing new members to a spreadsheet and posting the list via the API.
Every Monday I say hi to my new members who joined over the last week.
Usually I extract the full user list and elaborate a bit with my spreadsheet editor: cutting old members, ordering by creation date..
Then I elaborate a bit with a couple of “sed” on my linux shell in order to have a list of members like this: @jondoe - John Doe - Italy
Is there any chance to have this kind of feature on Discourse? Like Facebook groups for example
So I click a button and it sets up a new topic for me?
Have you looked at the data explorer plug in? It’ll let you create a query to get the data you want. If you know what sed is, you can likely get your data with curl and do a tweak with curl.
Another way is you could use a webhook and zapier to write the new members to a spreadsheet and more than likely then have it automatically copy them into a post and send back through via the api on a regular basis
