The discussion revolves around a user tip in Discourse that refers to the “three dots” menu, which is not visible on certain accounts or instances. Hayden James noticed the tip pointing to a non-existent menu, especially on new accounts with low trust levels. Bas and Tobias Eigen explain that the three dots only appear when there are too many menu items to display, and the tip is misplaced when the menu is not hidden. Tobias Eigen confirms this is a bug and notes that the issue affects sites where the post menu is not customized. The thread also touches on how user tips can be re-enabled via preferences, though some tips, like “Keep reading!”, are misaligned due to recent interface changes. Moin suggests using try.discourse.org for testing without creating accounts, while Hayden James thanks the team and confirms the test account was deleted as per rules.
What three dots is the pop-up referring to? This is as-is no scrolling.
I really wish this app had a LTS version that was recommended. Because I have read from devs on the forums that “Stable” should be avoided, and that beta should be used in production.
Am I missing the 3 dots in my meta login? Thanks for any clarity.
P.S. I did the in icognito browser just to make sure nothing was session/cache related.
You can use try.discourse.org. Then you don’t have to create a new account here (But I think you automatically get trust level 1 there, so you are able to flag posts and the 3 dots appear).
Thanks, Hayden! Looks like you uncovered a bug with that user tip. If the site you are on does not hide any post menu items behind ... then the ... is not shown and that user tip is orphaned and shown in the wrong location. We’ll get this fixed.
More about hiding post menu items.
There is are admin settings for post menu and post menu hidden items. By default, there are nine of them (eight for non-staff) which is alot, so five of them are hidden behind the .... If a site, like meta, decides to show fewer of them and to not hide them, then the ... is not shown.
For future reference, you can display the user tips again by selecting the Show user tips again button on your user preferences > interface. You don’t have to create test user accounts for that purpose. Though the first user tip is not shown again, which is a known but low priority bug.
I also noticed the “Keep reading!” user tip is a bit off. This is related to the new “Related” tab in that location that was created later. Will also look into having this fixed.
I thought so too, but after you reached tl1 here on meta, you are able to flag and the 3 dots appear. So this is one of the issues you have to be at tl0
Ah, excellent. I see! I am able to replicate this now as a TL0 user on another site I manage.
This is an important discovery because it affects all sites that have left the post menu at the default, not just sites that have decided to not hide items behind the .... Even on my own site there is no ... on the post menu for TL0 users. I suspect it’s always been this way but we are only noticing now.
