What about adding tags in the top menu?
Possibly you guys might be on an older version of the tagging plugin?
As stated, we’re on .1. What is it up to?
Hmm, looks like 0.1 is the current version. I know @neil worked on this recently, can you clarify?
It looks like changes have been made without changing the version number
@techAPJ would know any details
from GitHub - discourse/discourse-tagging: Tagging functionality for Discourse Forums · GitHub
plugin.rb (where the version number is) - 1 month ago
assets/ - 14 days ago
config/ 22 days ago
3 Mi Piace
Uh oh, if we made changes without changing version number that’s… annoying. @neil should confirm tomorrow.
I will bump it to 0.2 now …
4 Mi Piace
I bumped the version to 0.2. I guess @sam forgot to push his bump?
4 Mi Piace
Since tags are now a core feature, are there any updates on the possibility to add them to the top menu?
If this is not enough
you can add a button via script
Read here
https://meta.discourse.org/t/how-to-add-external-link-on-top-menu/9508
4 Mi Piace
Search your admin settings for filter by tag
3 Mi Piace
i selected filter by tag
but my site dont effect. what the reason why?
And i added some tags. But dont appear on front page?
1 Mi Piace
You will have to be more specific.
Are the tags associated to a topic yet?
Did you refresh the page?
1 Mi Piace
Yup, i refresh my page a lot of on private tab
That is not where you add tags.
That is where you specify existing tags.Though it seems to let you put anything in there, it isn’t validating against the current tag list.
To add a tag, you need to edit a topic title or create a new topic and add the tag that way.
1 Mi Piace
i created some topic but i can’t add tag, because dont have tags to add.
So, where can i add tag?@cpradio Thank you for surpport
Screenshots/a link to your site would be really helpful.
Are you an admin? If so, and if you have Tags properly enabled, you should be able to add a tag to any topic.
When you created the topic you didn’t see a text input below the textarea?
If you click the title edit pencil you don"t see a text input below the category select?
I have a feeling you may be confusing topic tags with hashtags in posts.
1 Mi Piace
http://canthuenhadat.com.vn
user: hidden
pass: > in your message
Okay, so Go to a topic, click on the pencil icon at the topic title. Enter hoa, press Tab or click the yellow highlighted result, click the Blue checkmark to save the topic with the tag.
1 Mi Piace
Yep, don’t see text input when create topic
Category is appear
wow, i dont see different between tags and hashtag in post. i only create classify
