What about adding tags in the top menu?
סיכום מבוסס בינה מלאכותית
The discussion revolves around adding tags to the top menu in Discourse. Matthieu proposes adding a link to /tags or /tags/tag_name as an item in the top menu. sam requests a mockup, and Mittineague shares a mockup, highlighting issues with the current tagging system.
Some users, like ChrisAnderson, express interest in having this feature, especially for organizing knowledge base articles. Others, like lisajill, point out that tags are important and currently hidden.
codinghorror mentions that allowing admins to place arbitrary links in the topnav would solve this issue and others. sam notes that adding links is easy, but maintaining the breadcrumb is harder.
The discussion also touches on the tagging plugin, with cpradio mentioning that the plugin supports a setting to show a tags dropdown in the top menu. However, lisajill and huynhthai824 have trouble finding this setting, and cpradio explains that the setting is not for adding tags, but for specifying existing tags.
huynhthai824 shares screenshots of their site, and cpradio and Mittineague provide guidance on how to add tags.
Finally, Johani mentions that it is now possible to add custom top navigation links using a theme component.
Did you think about adding the ability to include a link to /tags or /tags/tag_name as an item in the top menu ?
8 לייקים
Mockup please?
I realize our Tagger is different, but IMHO the way it is accessed works fine
The main problems I see with it are that
  • it needs work in the “Create Topic”
  • Tags are often used inappropriately
And disregard the border color around the tags (that isn’t actually how it is shown on our instance).
Thanks, I tend to forget I have my userscripts mucking about.
Something like this ?
Maybe with an option such as |Tags| or |Tags/mytag| in the top menu setting ?
14 לייקים
Also, the tags seem to appear in a pretty random order and are difficult to find - especially in “Create Topic”. Editing a topic presents them alphabetically, which makes them easier to work with, IMHO.
2 לייקים
So… is this feature find a place in your sweet hearts ? :heartpulse:
לייק 1
I think this would be logical to have an option to add it as an item in top menu. :+1:
We already have the page (https://meta.discourse.org/tags) anyway.
I think it would be neat if we had an additional setting in /admin that defines a threshold of minimal use for a tag to be listed there.
For example: I would like /tags to list only tags that have been used more than once.
I have said for a long time .. it’s criminal that we don’t allow admins to place arbitrary links in topnav.
That would solve this and many more issues.
21 לייקים
Adding the links is the easy part, the hard part is maintaining the breadcrumb. If we allowed admins to add “Tags” or “Users” there we also need to allow to carry the top nav around and keep it highlighted.
4 לייקים
+1 on this feature. I’m hoping to move all of our knowledge base articles over to Discourse from Zendesk, but we currently have Docs>Category>Section>Article, which in Discourse will need to translate to Tag (i.e. tag all kb articles “DCU” which is our branding for docs)>Category>Sub-category>Topics. In this case, I’d like to be able to put the “DCU” tag in the top menu.
Any workaround suggestions in lieu of there not being an admin setting for this? I’m going to ask our engineers to see if someone can work on this, but would be great to point to an example or workaround. Thanks!
Was just searching to see if this feature was hidden away somewhere. Tags are important and hidden; we need a way to surface them on the front page. A menu item the likes of “Latest” and “Top” would be ideal for us.
לייק 1
There is a feature to put a Tags drop down in front of that menu in the admin area.
Setting is show filter by tag
4 לייקים
Thank you @cpradio! :sunglasses:
I am trying to find this option (using the search for site settings) and can’t find it. Version: 1.5.0.beta2
Look admin > settings > plugin.
לייק 1
It is definitely in the tagging plugin supported by the Discourse Team
The tagging plugin we have is v0.1 and this is the screenshot of the config settings for that plugin. A search on all site settings for ‘filter’ or ‘tag’ brings up nothing similar to what you describe.
