ما الذي تغير في كل إصدار مستقر؟
Is there a way to easily see what functional changes and/or fixes are in a discourse point release ?
Did you try The releases category?
Yes - but I’m looking to find out what’s changed between 1.5.1 and 1.5.2 for example.
Short Answer GitHub:
And if you are on 1.5.1, you should upgrade to 1.5.2, as it seems to be all security fixes.
5 إعجابات
Yep, the policy is that updates on the stable branch are only (a) security fixes or (b) high-profile / high-impact bugfixes that have already landed in master for a bit.
4 إعجابات
تم إغلاق هذا الموضوع تلقائيًا بعد 2936 يومًا. لم يعد يُسمح بالردود الجديدة.
