What does posts.word_count column mean in the database?
I need word count per topic for a badge query.
I found the word_count column in the posts table, but it seems not what I need.
For instance, this raw text:
так тут і питання, що якщо без вакцин ніяк, то обійдусь без кролів. Але є в деяких людей позитивний досвід, 3 роки без хвороб і вакцин один з них. Тримають в ямі.
Has a word_count = 1.
So, it is either a bug in how word counting works, or the column is simply supposed to do something else.
Please advise.
AFAIK word_count is the site setting used for the “too short” modal, not a count of the words in a post.
I doubt that data exists. Not that it couldn’t get got, but I fear it would be a massive resource hog to do retro.
Not sure how a site setting is related to a column in the posts table.
word_count” is computed with “raw.scan(/\w+/).size” which unfortunately doesn’t work properly on non-latin sentences… :frowning:
I’m thinking of replacing it with “raw.scan(/[[:word:]]+/).size” which returns 32 for your example sentence. Is that correct?
["так", "тут", "і", "питання", "що", "якщо", "без", "вакцин", "ніяк", "то", "обійдусь", "без", "кролів", "Але", "є", "в", "деяких", "людей", "позитивний", "досвід", "3", "роки", "без", "хвороб", "і", "вакцин", "один", "з", "них", "Тримають", "в", "ямі"]
EDIT: FYI this value is used to compute the “read_time” of the topic :wink:
Your fixed example looks good!
Here’s the fix :sunflower:
