Was muss ich für eine vollständige Installation tun?
Hell,
I have a dedicated server with plesk and I install image docker/base when I try to lauch after few second shout down.
The log is empty and in the setting is few fields…take a look
What i need to do for install?
The easiest thing to do is first remove or disable Plesk. Then you can follow discourse/docs/INSTALL-cloud.md at main · discourse/discourse · GitHub in less than 30 minutes. Installing with plesk will take several hours and few people here have experience or the interest in helping you,
i need plesk…sorry I cant disable or remove.
If it’s a dedicated server then plesk is not going to help you at all,but if you want to use it anyway, you should seek help on the plesk forum.
yes i did and wiating reply
