What is the difference between raw.hbs handlerbar files and only .hbs handlerbar files?
סיכום מבוסס בינה מלאכותית
In a Discourse development discussion, users explore the difference between .hbs and .raw.hbs (or .hbr) Handlebars templates. net_deamon notes that some plugin outlets (like topic-list-after-title) use {{raw-plugin-outlet}}, requiring .raw.hbs files, while others use {{plugin-outlet}} with standard .hbs files. sam clarifies that raw templates are a performance optimization—they lack full Ember lifecycle features like setupComponent, making them faster but less flexible. spirobel asks about alternatives to setupComponent and computed properties in raw templates; they later find a workaround by reopening models to add computed properties accessible in .raw.hbs. merefield questions whether raw templates can be backed by JavaScript components like regular ones. They discover that some components (e.g., topic-list-item) use .hbs templates that render .hbr templates via JavaScript, suggesting raw templates don’t directly support JS unless manually bridged. markvanlan recommends using helpers for JS logic in raw templates, citing an example from the discourse-category-experts plugin. merefield reports switching some .hbr to .hbs to enable closure actions for passing data up the component tree, despite performance trade-offs. markvanlan and merefield discuss whether helpers can handle upward data flow, with merefield noting the need to persist computed image properties from leaf components to grandparent for styling. In summary, raw templates offer speed but limited interactivity; JS logic must be added via helpers or model extensions, or avoided by using full .hbs components when complex data flow is needed.
I noticied that few plugin outlet like topic-list-after-title require raw.hbs file
while other require only hbs file.
I did search in the handlebars documentation, but I could see anything as raw hbs file.
I checked in the discourse code, plugin outlet like topic-list-after-title are defined as
{{raw-plugin-outlet name="topic-list-after-title"}}
while other plugins are defined as
{{plugin-outlet name="composer-fields-below" args=(hash model=model)}}
Q1. Is there any reason why some plugin plugin are defined in above way ( raw-plugin-outlet) ?
Also I noticied that in the raw.hbs file, the setupcomponent is not called as explained in this link
Q2. Is it so? I had also asked similar question regarding this.
I would be interested in this as well. Did you find the answer yet? :grinning:
Raw templates are a performance optimisation. Only partial ember view features exists, removal of features is what makes it faster.
Hence we use a different pattern here for extensibility. We don’t have the full ember lifecycle.
Is there something similar to setupComponent(args, component) with the raw outlets as well? What about computed properties? I would like to do some computations based on the data in context. How can I go about this? I dont even know if I named my accompanying .js.es6 file right. Should I name it .raw.js.es6?
SetUpComponent not being called for topic list tags plugin outlet - #3 by net_deamon
Okay I found the solution: reopen the Topic model and create a computed property there:
https://github.com/paviliondev/discourse-events/blob/master/assets/javascripts/discourse/initializers/event-edits.js.es6#L74
Afterwards it can be used int the raw template:
https://github.com/paviliondev/discourse-events/blob/master/assets/javascripts/discourse/connectors/topic-list-after-title/topic-list-event-rsvp.raw.hbs#L5
I have the same question.
Is it possible to ‘back’ a raw template with corresponding javascript as per regular Components, within a Theme Component.
I’ve got quite a challenging use-case and I need to manage actions to pass arguments back up the component chain from a deeply embedded template within the topic list.
I note there are several .hbr files with apparently corresponding Javascript Component elements in the Discourse source but noticed something odd, e.g.:
merefield@development:~/discourse$ find . -type f -name "flat-button.*"
./app/assets/javascripts/discourse/app/templates/flat-button.hbr
./app/assets/javascripts/discourse/app/templates/components/flat-button.hbs
./app/assets/javascripts/discourse/app/components/flat-button.js
merefield@development:~/discourse$ find . -type f -name "topic-list-item.*"
./app/assets/javascripts/discourse/app/templates/mobile/list/topic-list-item.hbr
./app/assets/javascripts/discourse/app/templates/components/topic-list-item.hbs
./app/assets/javascripts/discourse/app/templates/list/topic-list-item.hbr
./app/assets/javascripts/discourse/app/components/topic-list-item.js
merefield@development:~/discourse$ find . -type f -name "topic-post-badges.*"
./app/assets/javascripts/discourse/app/templates/components/topic-post-badges.hbs
./app/assets/javascripts/discourse/app/templates/topic-post-badges.hbr
./app/assets/javascripts/discourse/app/components/topic-post-badges.js
There appears to be several instances, therefore, where there are .hbr and .hbs flavours of a specific Component?
Ah, at least with topic-list-item I see the switch is made here:
Contents of hbs file:
{{topicListItemContents}}
backing Javascript:
  @observes("topic.pinned")
  renderTopicListItem() {
    const template = findRawTemplate("list/topic-list-item");
    if (template) {
      this.set(
        "topicListItemContents",
        template(this, RUNTIME_OPTIONS).htmlSafe()
      schedule("afterRender", () => {
        if (this.selected && this.selected.includes(this.topic)) {
          this.element.querySelector("input.bulk-select").checked = true;
Sneaky!
So this suggests hbr files do not have underlying javascript files, unless supported by this kind of workaround?
Yes, I believe this is the case. If there’s another way, I haven’t seen it!
That observer is not ideal as we are trying to get away from them as we continue to upgrade Ember. I think a better way is to create a helper and put your JS in there. Here is an example
https://github.com/discourse/discourse-category-experts/blob/main/assets/javascripts/discourse/connectors/topic-list-after-title/category-experts-indicator.hbr
In some recent work, I’ve needed some of the template “tree” to be able to communicate data up from a leaf template using closure actions, so I’ve switched some of the hbr’s to hbs’s to support his.
The work is experimental and I appreciate this will have a performance impact, but after iterating the design a few times was unable to find an alternative way of doing this whilst keeping “in-framework”.
Can you not pass functions into a helper, and call them there? I don’t think I’ve tried this but I imagine you could do it.
Specifically, I’m determining properties of an image in a leaf component, then storing them as properties of the grandparent to influence styling that must persist beyond the current list render. The data definitely has to pass up. If a helper can achieve that that sounds like a good option if I get stuck with current approach, thanks!
