The discussion revolves around the SetUpComponent not being called for a topic list tags plugin outlet. net_deamon initially tried to add a plugin outlet for topic list tags, but was unable to get the corresponding js.es6 file to work. tgxworld pointed out that the topic-list-tags plugin outlet has been removed and suggested using the plugin-api instead.
net_deamon then tried using the topic-list-after-title plugin outlet and was able to view test text, but the SetUpComponent was not called. The js.es6 file was located at my-plugin/javascripts/discourse/connectors/topic-list-after-title/test-topic-list-after-title.js.es6, which should have triggered the SetUpComponent.
spirobel shared that they are experiencing the same issue and has not found a solution. They provided a link to a related discussion on adding computed properties to raw hbs outlets.
Thanks for your reply. I see there is another plugin outlet “topic-list-after-title”.
I added the raw.hbs file in the “topic-list-after-title” folder. I added some test text in the raw.hbs file, and I was able to view the same in the discourse site.
