Hello everyone, can anyone tell me what the minimum server power requirements are for the new version of Discourse 3.1?
https://github.com/discourse/discourse/blob/main/docs/INSTALL-cloud.md#3-create-new-cloud-server
- The default of the current supported LTS release of Ubuntu Server works fine. At minimum, a 64-bit Linux OS with a modern kernel version is required.
- The default of 1 GB RAM works fine for small Discourse communities. We recommend 2 GB RAM for larger communities.
- The default of New York is a good choice for most US and European audiences. Or select a region that is geographically closer to your audience.
TL;DR:
1GB RAM, latest LTS of Ubuntu
And with that 1 GB RAM must increase manually size of swap.
So, real world minimum is 2-4 GB.
And size of the disk depends. But quite fast S3 will be cheaper choise than buying more disk from hosting.
