What is the rule for Invite User feature?
The option for invite users is visible for some users, for example:
However, for another users, this button doesn’t exist.
What is the rule for this button?
לייק 1
They must earn trust level 2 or higher.
5 לייקים
Can i change this level ?
No. Though, I think it’s reasonable to add this feature. There is a site setting to change the default invitee trust level.
Trust level 2 is very easy to attain. It’s reasonable to expect someone to be TL2 before they invite others. If they’re really desperate to introduce others before there’s always the “register” button.
לייק 1
In the meanwhile, a Settings - Trust Levels - min trust level to allow invite setting has been added which allows you to set the required trust level to be able to invite users.
2 לייקים
