When using the calendar plugin, this odd “arrow” appears under topics in the category view when you hover your mouse over a topic:
It’s also just a little wonky in the context of the theme in general, but it’s possible this is just my custom theme…
I think it might be an empty one of these: (Discourse Tooltips )
I wouldn’t have guessed that, my bad
The next time your site is updated those weird houses will be gone!
main ← no-text-fix
merged 03:42PM - 07 Jul 23 UTC
Reported: https://meta.discourse.org/t/whats-with-this-weird-house-i-mean-arrow/… 270838
There are some cases where a post may have content like an event or a spoiler, and no other text. So we should check if there's text before attempting to display a tooltip.
Canapin
(Coin-coin le Canapin)
July 7, 2023, 3:48pm
5
But where will the calendar gnomes live after then?
If I had a dollar for every bug I found in Discourse…I’d have a few bucks. But if I had a dollar for every problem Discourse has solved for my community, I’d be set for life!
Thanks for removing the monopoly house from my UI
