When i rebuild it stoped on get acme.sh script
hello, discourse
when i rebuild, it stop on curl https://raw.githubusercontent.com/acmesh-official/acme.sh/3.0.6/acme.sh > /opt/acme.sh
my server is in chinese,
how can i do on this with my server.
two problem:this precompile file is also take more time in my chinese server, is it possible skip it and make core build directoly
You may need a proxy when rebuilding on a server in mainland China.
Here’s the announcement about the precompiled assets
As suggested, you’ll likely need a proxy or some other way to get acme. If necessary, you could fork or otherwise modify web.letsencrypt.ssl.template.yml to retrieve acme.sh from somewhere else.
yes, this two works perfect, thanks very much.:rose:
ssl: i change it to a proxy:
curl https://ghfast.top/https://raw.githubusercontent.com/acmesh-official/acme.sh/3.0.6/acme.sh > /opt/acme.sh
pre-compiled: DISCOURSE_DOWNLOAD_PRE_BUILT_ASSETS this works very well.
Glad that worked!
There’s some better way to add the proxy.
You are likely to get an error the next time that template changes and when it does a git pull. You can do a ‘git stash’ to steam your change
