j127
7 augustus 2019 om 08:48
1
Does anyone know how to query staff notes notices from the database? I’ve been looking around in the code but haven’t been able to find where they are stored.
My main goal is to find a specific staff notice that was written in the past week, so I’m looking for a way to skim through the recent custom ones.
Edit: I was having trouble, because I was looking for “staff notes”. I’ve just found a custom_field that might be what I’m looking for, but I’m not sure how to list all the staff notices with custom text.
pry(main)> p.custom_fields
=> {"notice_type"=>"new_user"}
tgxworld
(Alan Tan)
7 augustus 2019 om 08:53
PlugintStoreRow.where(plugin_name: "user_notes") is probably what you’re looking for
j127
7 augustus 2019 om 08:56
3
Thanks, I’m looking for “staff notices” (core feature), which I think is different from “user notes” (separate plugin). I might be confused though.
The item named “Add Staff Notice”:
tgxworld
(Alan Tan)
7 augustus 2019 om 11:45
4
It should be in the custom fields like you’ve mentioned
def notice
raise Discourse::NotFound unless guardian.is_staff?
post = find_post_from_params
if params[:notice].present?
post.custom_fields["notice_type"] = Post.notices[:custom]
post.custom_fields["notice_args"] = PrettyText.cook(params[:notice], features: { onebox: false })
post.save_custom_fields
else
post.delete_post_notices
render body: nil
j127
8 augustus 2019 om 06:40
5
Thanks. In case anyone else is looking for a quick way to skim the data, this works in the Rails console:
results = Post.all.reject { |p| p.custom_fields['notice_type'].nil? }
results.each do |r|
puts r.custom_fields
Sample output:
{"notice_type"=>"returning_user", "notice_args"=>"2018-08-04T07:43:52Z"}
{"notice_type"=>"returning_user", "notice_args"=>"2016-10-11T09:32:30Z"}
{"notice_type"=>"returning_user", "notice_args"=>"2014-04-02T16:16:04Z"}
I don’t see any custom text there, so I guess the staff notice I was looking for isn’t live.
