Is there a way to view all staff notices? Thank you!
You can use the Data Explorer plugin and run this query to view all staff notices:
SELECT post_id, value::json->>'raw'
FROM post_custom_fields
WHERE name = 'notice' AND value::json->>'type' = 'custom'
Thank you! I wasn’t able to find the custom field but I’ll check it out now ![]()
Yes! It worked and thank you for the json because it wasn’t going to be easy to filter the ‘custom’ notices
