Where is the upgrade button
The discussion revolves around an issue with the upgrade button in Discourse, where user Idan cannot find it and encounters an error during the upgrade process. Alankrit_Choudh suggests accessing the upgrade page directly, but Idan faces a bundling error related to HTMLBars templates. The error log points to a plugin issue, which sam identifies as the cause. Idan confirms the upgrade succeeded after removing third-party plugins. He then asks about the reliability of the AWS AMI backup method, and Falco confirms that the backup procedure is reliable for restoring the server in case of failure. Idan expresses gratitude for the support.
I can’t find the upgrade button in the UI. It says “updates are available. Please Upgrade!”. I remember using an upgrade button somewhere before for upgrading the files, but now I can’t see it.
There is no click to upgrade link.
Trying to upgrade from v1.7.0.beta7+9 to 1.7.0.beta8
try
yoursite.com/admin/upgrade
to get to the upgrade page.
I’ve got a “There was an error upgrading..” message. Trying again from that /admin/upgrade url to see if it works.
I get:
“Sorry, there was an error upgrading Discourse. Please check the logs below.”
Last line says: “Bundling assets”.
This is an error line I found in the log:
MiniRacer::RuntimeError: Error: ‘SCRIPT’ tags are now allowed in HTMLBars templated (on line 11)
Here’s the entire log:
== Seed from /var/www/discourse/db/fixtures/500_lounge_category.rb
== Seed from /var/www/discourse/db/fixtures/501_meta_category.rb
== Seed from /var/www/discourse/db/fixtures/502_staff_category.rb
== Seed from /var/www/discourse/db/fixtures/999_settings.rb
== Seed from /var/www/discourse/db/fixtures/999_topics.rb
***  Bundling assets. This might take a while ***
$ bundle exec rake assets:precompile
Purging temp files
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/cached_environment.rb:20:in `block in initialize'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/cached_environment.rb:47:in `load'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/bundle.rb:23:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/utils.rb:196:in `dfs'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/bundle.rb:24:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/processor_utils.rb:75:in `call_processor'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/processor_utils.rb:57:in `block in call_processors'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/processor_utils.rb:56:in `reverse_each'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/processor_utils.rb:56:in `call_processors'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/loader.rb:134:in `load_from_unloaded'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/loader.rb:60:in `block in load'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/loader.rb:317:in `fetch_asset_from_dependency_cache'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/loader.rb:44:in `load'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/base.rb:66:in `find_asset'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/base.rb:73:in `find_all_linked_assets'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/manifest.rb:134:in `block in find'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/manifest.rb:133:in `each'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/manifest.rb:133:in `find'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/manifest.rb:185:in `compile'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-rails-3.1.1/lib/sprockets/rails/task.rb:68:in `block (3 levels) in define'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/rake/sprocketstask.rb:147:in `with_logger'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-rails-3.1.1/lib/sprockets/rails/task.rb:67:in `block (2 levels) in define'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rake-11.2.2/exe/rake:27:in `<top (required)>'
/usr/local/bin/bundle:23:in `load'
/usr/local/bin/bundle:23:in `<main>'
MiniRacer::RuntimeError: Error: `SCRIPT` tags are not allowed in HTMLBars templates (on line 11)
JavaScript at validateStartTag (<anonymous>:23146:13)
JavaScript at Parser.finishStartTag (<anonymous>:23019:7)
JavaScript at Parser.finishTag (<anonymous>:23003:14)
JavaScript at Object.tagName (<anonymous>:25040:25)
JavaScript at Object.tokenizePart (<anonymous>:24864:33)
JavaScript at Parser.ContentStatement (<anonymous>:22843:22)
JavaScript at Parser.acceptNode (<anonymous>:23216:27)
JavaScript at Parser.Program (<anonymous>:22743:14)
JavaScript at Parser.BlockStatement (<anonymous>:22770:42)
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/mini_racer-0.1.7/lib/mini_racer.rb:167:in `eval_unsafe'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/mini_racer-0.1.7/lib/mini_racer.rb:167:in `block (2 levels) in eval'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/mini_racer-0.1.7/lib/mini_racer.rb:217:in `timeout'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/mini_racer-0.1.7/lib/mini_racer.rb:166:in `block in eval'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/mini_racer-0.1.7/lib/mini_racer.rb:63:in `block in with_lock'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/mini_racer-0.1.7/lib/mini_racer.rb:63:in `synchronize'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/mini_racer-0.1.7/lib/mini_racer.rb:63:in `with_lock'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/mini_racer-0.1.7/lib/mini_racer.rb:164:in `eval'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/execjs-2.7.0/lib/execjs/mini_racer_runtime.rb:27:in `block in eval'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/execjs-2.7.0/lib/execjs/mini_racer_runtime.rb:66:in `translate'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/execjs-2.7.0/lib/execjs/mini_racer_runtime.rb:26:in `eval'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/execjs-2.7.0/lib/execjs/mini_racer_runtime.rb:34:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/barber-0.11.1/lib/barber/precompiler.rb:31:in `compile'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/barber-0.11.1/lib/barber/precompiler.rb:8:in `compile'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/ember-handlebars-template-0.7.4/lib/ember/handlebars/template.rb:166:in `block in precompile_ember_handlebars'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/sprockets-3.6.3/lib/sprockets/cache.rb:85:in `fetch'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/ember-handlebars-template-0.7.4/lib/ember/handlebars/template.rb:165:in `precompile_ember_handlebars'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/ember-handlebars-template-0.7.4/lib/ember/handlebars/template.rb:89:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/ember-handlebars-template-0.7.4/lib/ember/handlebars/template.rb:39:in `call'
Tasks: TOP => assets:precompile
Bundling assets
I guess the discourse team will take it from here.
On the other note, always keep a backup.
Do try upgrading manually as well – SSH to your server and in the discourse directory
use these commands to manually upgrade
git pull
and
./launcher rebuild app
I get:
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake assets:precompile' failed with return #<Process::Status: pid 367 exit 1>
Location of failure: /pups/lib/pups/exec_command.rb:108:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"bundle_exec", "cmd"=>["su discourse -c 'bundle install --deployment --verbose --without test --without development'", "su discourse -c 'bundle exec rake db:migrate'", "su discourse -c 'bundle exec rake assets:precompile'"]}
9a988e533a92c5649b6c9e634b60ad1ef08d5c9e97e06812dca1d59daa64542e
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one
One of your plugins is bust, recommend removing all 3rd party plugins and trying again.
I posted it in the wrong topic lol.
@sam The upgrade is finished successfully and it was indeed that plugin. I will stay without plugins for now, just to have a piece of mind. So thanks a lot!!
I wanted to ask you a question. Before the upgrade, I used the AWS AMI to backup the server. I created a new server with that AMI and when I tried to access the website, it didn’t load, any idea why.
Can I count on the BACKUP procedure so in case the server is crashed for some reason, I can create a new server from scratch, install discourse and use the BACKUP and restore everything back to the previous state?
Thanks in advance.
Yes.
Before updating you can backup and then download the backup locally. If the server catches fire starting over in another is easy.
That’s excellent to know, thanks.
