Which plugins are freely available?
Here Plugin directory | Discourse - Civilized Discussion they look available only for paid hosting plans.
Or please correct me.
In particular, I’d like to install solved plugin.
Here are the plugins avail
Official Discourse Plugins:
https://meta.discourse.org/tags/c/plugin/22/official
Discourse Plugins:
Awesome, Gavin!
Thanks a lot!
Yep, and if you want to get technical, there is usually a licence within each Plugin.
The filename is usually Licence.txt or similar, is placed in the root directory of the plugin code and it will explain the terms, e.g.: discourse-locations/LICENSE.txt at main · merefield/discourse-locations · GitHub
Almost always, the licence is a standard one.
Here’s a good guide on the more popular Licences: Which License to Use for Open Source Projects?
The details of these licences can be important, especially if you wish to use a plugin for commercial purposes (many licences permit that, btw).
