And if I prefer to read it in French?
Why is Spansih the default? (Out of interest but no lack of affection for Spanish)
I am french and Brazilian and it feels good for me
Haha. Great combination.
I’m just curious why Spanish?
Does it pick language at random when translating from your native language?
I dont understand. My post in english are now in french for me. I dont know how its works
I think it’s gone rogue.
You should see everything translated into your locale as long as your locale is supported/selected to be translated by the forum admin.
Sometimes it does weird things.
This is a little quirk with the LLM now, but should be fixed with better prompts soon.
Currently the prompt for determining a post’s locale is as such:
The LLM usually fails at its job when the post contains some amount if a language, or indicating that it is a certain language, e.g.
“This post is written in Portuguese” → “pt” when it should be “en”.
This incorrect classification issue can be rectified if we update our post to the correct language, or indicate the correct language… but currently the locale-edit feature is only available to certain groups – just updated it to TL3, which means TL3 folks should now see the
when editing a post (see screenshot below).
There are many quirks with this whole new feature, like locales with regions (en, en_UK), and how one LLM fares better than another.
Regardless this is a good experiment so I’ll be fine-tuning it, so this topic is much appreciated! Docs are coming very very soon.
EDIT: Oh, I just realised only TL4 can edit posts. Will need to re-think this feature.
Are image descriptions also included in the AI’s analysis of the post?
You have a keen eye – yes currently. But we’ve an internal task to refine the prompt to exclude things in quotes and captions.
I see. I had an idea that if a user posts a screenshot of e.g. a forum in another language, the captions may be in that language, causing the post to be translated.
That is Spanish by the way.
Oh boy. Lol. I wrote that first then in my haste deleted and recreated it. I double checked with ChatGPT and it stated Portuguese
. Apologies. Fixed. Same issue though. AI running amock.
Here’s a screenshot @falco to prove I did some (eroneous) due diligence
Or maybe what’s happening is it keeps switching and it was indeed Portuguese at one point … but at the point I took the OP screenshot it was in Spanish … I’m so confused …
