Why "KB" in "Max image size KB" when unit is selectable?
In these settings:
Why does it say “KB” in the setting name when we can select KB, MB or GB as a unit? Is this some hold over from the past?
Should I make an issue on GitHub about this?
It’s because the saved value is converted to KB.
But if the user doesn’t see how it is saved, then what’s the point?
Hmm, maybe because “image size” is ambiguous? But the fact that the units are given should make it clear what is going on.
You make a valid point.
The feature to select the unit was introduced later. You had to convert it manually to KB before.
For the user, it might indeed be confusing. For the devs, it’s helpful to know.
Should I post this somewhere else to alert the devs?
no need, the team reads all the posts on this site
