なぜミックスウィジェットとハンドルバーを併用するのですか?
Hi everyone, I’ve tried to customize our discourse for about a month.
Then I’d like to ask why mixes widget and handlebars together?
I think that makes code more complicated and hard to maintain.
For an example, I want to move Create Topic button to header, then I just realized the button is created in hbs but header is in widget.
I really want to know the reason why you want to combine different things together.
I know for performance issue widget is a good tool, but don’t you think that is harder to trace and revise?
And there is another question: Does anyone know how to trigger event in widget from ember controller?
I’ve been stuck on the confusing architecture for a while..
For performance reasons.
It does, but it’s a tradeoff we are ok to make for our hot paths.
thank you for replying quickly,
Do you know how to interact with widget from ember controller?
I’ve tried A tour of how the Widget (Virtual DOM) code in Discourse works - #57 by eviltrout, but it doesn’t work …
Search for “theme howto
My advice here would be to look at existing plugins like polls plugin etc.
There is a large list at: GitHub - discourse/all-the-plugins · GitHub
