G-Suite POP3 smetterà di funzionare il 15/02/2021?
Does anyone know if Google’s announcement yesterday (12/16/19) to stop supporting “less secure applications” for g-suite on 2/15/2021 affect a discourse installation that uses G-Suite for POP3 mail handling?
The announcement appears to say that all g-suite access must be through Oauth! (IMAP is specifically mentioned, but not POP3)
FYI - on 6/15/2020 - g-suite will stop allowing any new LSA users.
Most likely that is the case, yes.
I suppose this could be addressed with development, or with another email provider.
I see references to IMAP connectivity under development. Are there plans for this to support OAuth?
If I recall correctly, we chose g-suite/g-mail because it allows for sub-addresses which allows for the use of reply-keys in email addresses.
Does Discourse have any other recommended providers that support this?
You can consider using
Sembra che abbiamo guadagnato una tregua!..
