Works! ...but primary group priority is struggling
It seems that the default “Patrons” group works – then I added the other groups for the specific tiers, and that seems to work too (they joined both groups, it seems).
However, the default group defaults to the generic “any amount” tier. How to deal with this?
EDIT: …Or am I supposed to delete the “any amount” group so they only join 1 of the 2 groups?
You should be able to uncheck Automatically set as primary group on the Patrons groups.
