Specificaties schrijven voor put naar een aangepast pad/model
The discussion revolves around writing specs for a PUT request to a custom path in a Rails plugin, specifically testing updates to a model via a controller. pfaffman is struggling with specs that don’t behave as expected, noting that puts in the model (e.g., before_save) are logged, but puts in the controller aren’t appearing. They suspect the issue lies in how the model is created—using createServerFromParams instead of fabricating it properly. justin suggests fabricating the model instead of creating it directly, which pfaffman confirms resolves part of the issue. pfaffman also discovers that errors in the model (e.g., accessing a nil variable) can cause silent failures, preventing the model or controller from executing as expected, even though no errors are shown in spec logs. This highlights the importance of proper model fabrication and debugging model-level errors in tests.
I’m working on a plugin that adds a model. I am trying to write specs that test that the model (and controller?) are behaving as expected.
This code in an ansible library, is successfully PUTting to this path and updating a field in the model/record:
    headers = {
        'Api-Key': discourse_api_key,
        'Api-Username': discourse_api_username,
    payload = {
        "server[request_status]": status
    url = "%spfaffmanager/servers/%s" % (discourse_url, server_id)
    # raise Exception(url)
    result = requests.put(url, data=payload, headers=headers)
This is the spec that I am trying to write that tests updates to that path. I’m confused because I have a zillion puts in the controller and none of them are printing, though puts in the model (e.g., in a function called by before_save ) are showing up in the stuff I see in the rake autospec.
My best guess is that I’m screwing up the
# frozen_string_literal: true
require 'rails_helper'
describe Pfaffmanager::ServersController do
  fab!(:user) { Fabricate(:user) }
  fab!(:admin) { Fabricate(:admin) }
  fab!(:another_user) { Fabricate(:user) }
  fab!(:trust_level_2) { Fabricate(:user, trust_level: TrustLevel[2]) }
  before do
    Jobs.run_immediately!
  it 'can update status' do
    request_status = 'new status'
    sign_in(admin)
    s=Pfaffmanager::Server.createServerFromParams(user_id: user.id,
        hostname: 'bogus.invalid' , request_status: 'not updated')
    puts "can update status created server id: #{s.id}"
    params = {server: {request_status: request_status}}
    expect {
        put "/pfaffmanager/servers/#{s.id}", params: params
    }.to change { s.request_status }
    expect(response.status).to eq(200)
    expect(s.request_status).to eq('new status')
I spent pretty much all day on this yesterday and would appreciate any hints on solutions or techniques for debugging.
If s=Pfaffmanager::Server.createServerFromParams(user_id: user.id, hostname: 'bogus.invalid' , request_status: 'not updated') is the model you’ve created, you might need to fabricate it for the request test to work properly, similar to how the users are fabricated previously in your example.
Oh. So fabricating it rather than doing an actual create might be my problem? In the other specs, I, for example, use the above code to create a Server and then do a get to get the list of servers and confirm that a server with the proper hostname exists and that the correct number of servers gets returned.
It probably makes sense to figure out how to fabricate one the “right” way, though.
Thanks very much for your help. I’ll try that next!
I figured out my problem (or one of them, anyway). If you have errors in your model.rb file like something that tries to do something like variable_that_is_nil['xxx'], then the model fails but you don’t see any errors in the spec logs like you do in the rails log if you were “testing” with a browser. So it can seem like the model or controller isn’t getting called when it really is.
But I did actually write an actual Fabricator, so thanks for the push, @justin!
