Wrong icon referenced for "Tracked" notification level in Tag preferences
The discourse code references the wrong icon for “Tracked” notification level in Tag preferences:
The icon shown above is the fa-circle-o one used everywhere else for “regular” notification level, and it gets greyed-out. It should be (blue) fa-circle:
Seems impossible to fix this by any means other than asking for it to be corrected in the code, hence the bug report…
It’s a bit of a stretch to call that a Contribute > Bug
This should fix it:
https://github.com/discourse/discourse/commit/cd8d5124299793db5b8f02787fc0d0ca03dc7bdc
I will say that I agree with Régis this doesn’t qualify as a bug.
It’s tiny but would confuse users. Thank you!
For reference, we classify a bug as:
A bug report means something is broken, preventing normal/typical use of Discourse.
While an incorrect icon can certainly be confusing, it doesn’t prevent normal use of Discourse. We still want to fix Contribute > UX issues (as we did here), but we try to keep the Contribute > Bug category to things that truly break something.
OK - good to know, and apologies. I’ll do that next time.
