Link errado no e-mail de confirmação
Hello,
I’m having an issue with a discourse instalation. We had to change the OS so we had to reinstall Discourse, and then restore the backup. It’s running on the same server/ip/hostname.
The issue we have is with the url sent in the confirmation email, for new accounts or password change.
We get an https://email.domain.com/… instead of https://forum.domain.com/…
We are using the same smtp with the same settings, and it was working fine before the reinstall.
Any hint on where I can find the setting that is causing this?
thanks in advance,
Tiago
Which mail provider are you using?
Any chance you’ve enabled click tracking?
Hi Stephen,
it was indeed a tracking issue. It was working before 'cause we had some configurations on our old dns. Anyway I disabled tracking :slight_smile:
thanks for your help
