Erros de importação do Yahoo Groups
Working through a Yahoo Groups mbox import and hitting some errors. Not sure what direction to take at this point regarding debug and importation. Here are the errors I’m seeing so far:
https://pastebin.com/raw/2WTN3GTj
1 curtida
You are using the mbox script’ right? Worked well for me with no errors. Attachments are missing but not the end of the world in my case.
1 curtida
That is correct @tobiaseigen. The importation ran for over 2 hours.
In addition to the last question, I wanted to add that I wasn’t sure if I should proceed with importation of this even with these failures… wondering if after the errors/failures are fixed we can simply import them AGAIN and it will skip the already imported messages and just move on with proper importation.
1 curtida
@gerhard perhaps we need some input and help here… Even after going through your guide Sidekiq is not showing the processing of these ~35,000 messages.
1 curtida
Not sure sidekiq is relevant here - the import script runs outside discourse I think.
In case it helps, here’s my import log. There are in fact a few lines that are similar to yours, but I just decided not to worry about it. Life is too short.
Since you have so many errors, you seem to have have a more systematic problem. Are you sure the system has enough RAM available? I don’t know if you have already tried it, but you may want to look at the import file a little more closely and try to identify if there is anything you can find out there - maybe you just need to adjust the split_regex in some way, or upload the file to your server in a different format?
If you keep having trouble, you could ask for help in marketplace - there are some consultants hanging out here who are quite experienced at doing imports. I’m certainly no expert - this was my first attempt. :wink:
root@discourse:/var/discourse# ./launcher enter import
root@discourse-import:/var/www/discourse# RAILS_DB=secondsite
root@discourse-import:/var/www/discourse# export RAILS_DB
root@discourse-import:/var/www/discourse# import_mbox.sh
The mbox import is starting...
Loading existing groups...
Loading existing users...
Loading existing categories...
Loading existing posts...
Loading existing topics...
creating index
indexing files in /shared/import/data/list
indexing /shared/import/data/list/18929486-3.mbox
indexing /shared/import/data/list/18929486-2.mbox
indexing replies and users
creating categories
        1 / 1 (100.0%)  [4916421 items/min]
creating users
       69 / 69 (100.0%)  [1178 items/min]  ]
creating topics and posts
Date is missing. Skipping 0462b41b966d8c11e6e32cc14c0b576d
        1 / 2333 (  0.0%)  [179689 items/min]  Date is missing. Skipping 0adb9bd80082595a33130f7749d7f530
        2 / 2333 (  0.1%)  [224693 items/min]  Date is missing. Skipping 3bd86d7adb396fbeb7d6dfcfe9f0be5f
        3 / 2333 (  0.1%)  [283328 items/min]  Date is missing. Skipping 4f5397838e6c7f96eedfe116ce27be13
        4 / 2333 (  0.2%)  [184374 items/min]  Date is missing. Skipping c8c14ab80e92ae1cacd4af99351319bd
       45 / 2333 (  1.9%)  [334 items/min]  Failed to map post for 2f401ce90708241252h30bdae5iad2ae0096e067b71@mail.gmail.com
undefined method `hex' for nil:NilClass
/var/www/discourse/app/models/upload.rb:132:in `base62_sha1'
/var/www/discourse/app/models/upload.rb:386:in `short_url_basename'
/var/www/discourse/app/models/upload.rb:115:in `short_url'
/var/www/discourse/lib/upload_markdown.rb:17:in `image_markdown'
/var/www/discourse/lib/upload_markdown.rb:10:in `to_markdown'
/var/www/discourse/lib/email/receiver.rb:1085:in `block in add_attachments'
/var/www/discourse/lib/email/receiver.rb:1060:in `each'
/var/www/discourse/lib/email/receiver.rb:1060:in `add_attachments'
/var/www/discourse/script/import_scripts/mbox/importer.rb:137:in `format_raw'
/var/www/discourse/script/import_scripts/mbox/importer.rb:121:in `map_post'
/var/www/discourse/script/import_scripts/mbox/importer.rb:145:in `map_first_post'
/var/www/discourse/script/import_scripts/mbox/importer.rb:103:in `block (2 levels) in import_posts'
/var/www/discourse/script/import_scripts/base.rb:491:in `block in create_posts'
/var/www/discourse/script/import_scripts/base.rb:490:in `each'
/var/www/discourse/script/import_scripts/base.rb:490:in `create_posts'
/var/www/discourse/script/import_scripts/mbox/importer.rb:97:in `block in import_posts'
/var/www/discourse/script/import_scripts/base.rb:870:in `block in batches'
/var/www/discourse/script/import_scripts/base.rb:869:in `loop'
/var/www/discourse/script/import_scripts/base.rb:869:in `batches'
/var/www/discourse/script/import_scripts/mbox/importer.rb:83:in `batches'
/var/www/discourse/script/import_scripts/mbox/importer.rb:91:in `import_posts'
/var/www/discourse/script/import_scripts/mbox/importer.rb:35:in `execute'
/var/www/discourse/script/import_scripts/base.rb:47:in `perform'
script/import_scripts/mbox.rb:16:in `<module:Mbox>'
script/import_scripts/mbox.rb:10:in `<module:ImportScripts>'
script/import_scripts/mbox.rb:9:in `<main>'
      940 / 2333 ( 40.3%)  [398 items/min]  Failed to map post for BBCAF42471FF9540868B4DC02B885B1BBCDA1F@wn1217.or.providence.org
/var/www/discourse/script/import_scripts/mbox/importer.rb:159:in `map_reply'
/var/www/discourse/script/import_scripts/mbox/importer.rb:105:in `block (2 levels) in import_posts'
      944 / 2333 ( 40.5%)  [399 items/min]  Failed to map post for 3A1D6C799D451B41BD0500303339622A023AA1@s-mail.integral-corp.com
     1149 / 2333 ( 49.2%)  [408 items/min]  Failed to map post for FF35EE5B30156244A4370DC859B7F650F50626@s-mail.integral-corp.com
     2328 / 2333 ( 99.8%)  [467 items/min]
Updating topic status
Updating bumped_at on topics
Updating last posted at on users
Updating last seen at on users
Updating topic reply counts...
       70 / 70 (100.0%)  [10745 items/min]
Updating first_post_created_at...
Updating user post_count...
Updating user topic_count...
Updating topic users
Updating post timings
Updating featured topic users
Updating featured topics in categories
        9 / 9 (100.0%)  [2505 items/min]  n]
Updating user topic reply counts
       70 / 70 (100.0%)  [9174 items/min]   ]
Resetting topic counters
Done (00h 06min 58sec)
1 curtida
So I went ahead and allowed this to proceed (I’ll look at the errors later), but now I have a very big peculiarity. I had attempted to import these into a folder called “old-yahoo-group” by 1st creating this CATEGORY within the system and then I pushed all of the mbox folders into a folder here:
/var/discourse/shared/standalone/import/data/old-yahoo-group
I thought I had understood the instructions such that these messages, upon importation, would show up in the appropriate category, however they’re all hidden in the system.
I can do a search and find old messages just fine, however they do not appear in any aggregate location.
How can se manipulate this last import to go into a defined category such that all ~35k messages show up in a convenient section that indicates these are old messages?
Upon looking further, I appear to have found what happened:
Now I need to figure out how to recover from this…
So this worked perfectly (where old-yahoo-group had already been created and NO other uncategorized posts existed (and it was actually disabled in the Settings)):
/var/discourse/launcher enter app
rails c
un=Category.find_by_slug('uncategorized')
newcat=Category.find_by_slug('old-yahoo-group')
Topic.where(category_id: un.id).update_all(category_id: newcat.id)
Incidentally, I had a similar experience. For some reason the import script ignored the existing category I had created even though the slug was the same. But it created the new category for me so I had no problem. I just deleted the category I had created and renamed the category created by the script.
