You can no longer press ctrl+f twice to use native Find
I’m not sure when this changed but it used to be that ctrl+f once would bring up Discourse’s Find feature and pressing it a second time would bring up the browser’s native Find feature. I thought this was quite useful, but now the behaviour has changed and the second press closes Discourse’s Find and does nothing else.
1 « J'aime »
The searc function, can be active with /.
1 « J'aime »
No, this is a legitimate bug. On long topics, pressing CTRL + F will open the Discourse Search, press it again and it should open the native browser search.
PR of it working previously
3 « J'aime »
Yeah, that’s a regression. I think I know what the problem is… will fix it tonight.
2 « J'aime »
I bisected to this commit. Migrate search drop down to `menu-panel` component. · discourse/discourse@d4b987f · GitHub
We should probably add an acceptance tests too :blush:
1 « J'aime »
I think this should fix it:
https://github.com/discourse/discourse/pull/3844
I have no idea how to do this. Is it possible to check if the browser handled the event?
You can add it if you want. :wink: Would be great to see how this can be done.
8 « J'aime »
Thanks, all! Good job.
For anybody being bugged by the Ctrl+f key combination not working on some other websites which have taken it over…
I have found myself getting used to pressing Alt+d, Ctrl+f.
Alt+d puts you in the address bar, from there the search shortcut works.
(tested in Chrome).
6 « J'aime »
Merged! Thanks for the fix @gerhard.
6 « J'aime »
Confirmed works, thanks again!
3 « J'aime »
