Topic Status Filter
:discourse2: Summary Topic Status Filter will filter topics by their “open” or “closed” status.
:eyeglasses: Preview Preview on Discourse Theme Creator
:hammer_and_wrench: Repository Link https://github.com/discourse/discourse-topic-status-filter
:open_book: New to Discourse Themes? Beginner’s guide to using Discourse Themes
Install this theme component
Features
This theme component will help you to filter the topics by their status “open” or “closed”. It will add a dropdown filter next to the existing categories and tags dropdown. You can limit this component to particular categories using the theme setting enabled categories, else it will be displayed in all categories.
Settings
Name Description
enabled categories
Translation Default
topic_status_filter.all all
topic_status_filter.open open
topic_status_filter.closed closed
:discourse2: Hosted by us? Theme components are available to use on our Standard, Business, and Enterprise plans.
「いいね!」 29
Love it! Thanks!
It’s a real live-saver. We use Discourse as an internal project and taskmanagement system.
「いいね!」 11
Very cool, I hate to gift you the gift of work but I wonder would you be able to do a post on meta explaining how you are using Discourse internally, what is working well for you and what needs help? We may be able to give you more ideas to help with your workflow!
「いいね!」 15
Reply here:
Seems like it merited a new topic.
「いいね!」 11
Can we filter group tags theme component?
Discourse already having the tags filter. What do you mean by group tags theme component? And what is the use case?
「いいね!」 2
I think he means so the ‘open’ ‘closed’ component would work in tag-pages and tag-intersections. I second that, its something i’d love to put in our forum.
We currently just add the tag ‘backlog’ ‘sprint’ ‘doing’ or ‘done’ to show the status of a topic.
「いいね!」 1
これをタグにも拡張することは可能でしょうか。カテゴリだけでなく。
また、デフォルトで選択されるフィルターを指定するオプションがあると非常に便利です。
タグリストでタグを選択できます。
「いいね!」 1
しかし、タグから入力すると、選択肢がありません。
念のため確認ですが、このコンポーネントはページがリロード/閉じられた場合でも「open」のフィルター状態を保持しますか?
