In a Support discussion titled Is it possible to block a category from Upcoming Events?, jenroberts asks if it’s possible to exclude a category (like Templates) from the Upcoming Events calendar, since template events currently appear there. JammyDodger confirms this isn’t currently possible, though events only appear for users with category access. They suggest using the built-in recurring event feature, but jenroberts explains that recurring events don’t suit their daily shows with changing hosts and topics — they need a full weekly view, so they manually create individual events. maiki offers two workarounds: (1) using private templates via PMs (enabled by settings like discourse templates enable private templates), which only appear to authorized users, or (2) using the Reply Template component to create reusable event templates — for example, embedding an [event] tag inside a [wrap=template] block — which can be stored in a PM or staff-only category for quick reuse without appearing publicly on the calendar. Both solutions aim to streamline event creation while avoiding unintended calendar visibility.
We’ve been adding our recurring weekly events to display in the Upcoming Events calendar and were hoping to create a template to help with that (rather than just cutting and pasting from a document).
Unfortunately, if we create an event topic as a template, that event actually shows up on the Upcoming Events calendar as well. We could create it without the [/event] or something and add it later but chances are someone will forget.
Is there any way to block a category from displaying on the Upcoming Events calendar, especially a category like Templates?
I’m afraid it’s not currently possible to block a category from displaying events in the Upcoming Events calendar (though the events would only display for people who had permission to see the category, if that’s any help). I’m not sure how a Template of an event would work though? There is a ‘recurring’ option in the event itself if you had a regular weekly meeting, for instance. You can set it up to add a new one each week when the existing one has ended?
We have the same show each day but with different hosts and topics that we add below the event data so our members can see who’s going to be talking (and about what) and decide if they want to watch it. Right now, I’m cutting and pasting the event data over from a document, changing the dates, then appending the hosts to speed things up. It’s faster than filling in the event form each time. If I can build them as a template, it would be easier to have others do it so I’m not the only one (yes, they can use the document too but I thought templates would be cleaner and keep it all in the platform.)
The problem here is that recurring only creates the next event when the prior is over so it doesn’t give a good weekly or monthly view of what’s coming up. It’s probably fine for events that only happen once a month but for daily events, and to an extent weekly, but it’s nice to have a view of the whole week at a time so we create individual events.
