Van privé naar publiek: de zoektocht om AI-gesprekken naadloos te publiceren
In a discussion titled From Private to Public: The Quest to Publish AI Conversations Seamlessly, Jagster reports a UX issue where the ability to publish private AI conversations via the share button doesn’t work when a newly created mentionable AI-user is involved — even though the original AI persona (non-mentionable) can be published. The issue arises because the share button only appears after the original AI bot writes something, which doesn’t happen when the new mentionable AI-user is active in the same PM thread. Jagster suggests connecting the AI-bot/persona with its mentionable counterpart to restore seamless publishing, noting that using different personas via mentions is confusing for users. sam acknowledges the issue with “oh yikes, will get this sorted,” and confirms it’s been resolved via a GitHub pull request sam. The thread also humorously notes that AI-generated titles (like this one) are clearly marked — aligning with EU transparency requirements — so users instantly know if content is AI-generated :winking_face_with_tongue:.
We got nice option to publish private conversations with AI bot. Now we got (even it is not totally published yet) ability to mention bots.
There is small issue now. Those two don’t work together.
I can copy PM-conversation when it happends with persona, that can’t be mentioned. But right away after new mentionable AI-user is created, I have three party PM-topic, where are myself, original AI and new AI-user. But sharing button is visible only when original AI bot has written something, but that doesn’t happend because of newborn AI-user.
So can you connect AI-bot/persona and mentionable AI-user of that same persona that I can still publish PM-topic using that share-button-thing?
Sure. I can use different personas via mentions when almost identifal ones work via PM, but that is not an elegant solution and is very confusing to ordinary users[1].
(Yes, AI created the tittle and it shows… no matter what kind of AI badges EU will need an user sees rigjt away if content, text anyway, is by AI or not :winking_face_with_tongue: )
  1. as an admin I can use publishing PM via my private category, but… ↩︎
oh yikes, will get this sorted.
sorted per:
https://github.com/discourse/discourse-ai/pull/479
This topic was automatically closed after 17 hours. New replies are no longer allowed.
