Reply composer still broken on firefox mobile
re-opening this bug since it is still broken for me.
using fennec f-droid
120.0.0 (Build #1200020), 039de7ef85+
GV: 120.0-20231123222746
AS: 120.0.1
this seems to only happen at certain scroll positions, and the workaround is to scroll the page or move the cursor until discourse realizes something is wrong and snaps everything into place.
Broken on latest Firefox Beta from Play Store too.
132.0b7 (Build #2016050159), hg-c3f3d745360a+
GV: 132.0-20241014091808
AS: 132.0.1
GrapheneOS, so pretty much Android AOSP 2024101200.
It never snaps into place here. There’s also a silly little bit below (between reply button and keyboard) where the page behind is still visibly rendered and scrolling. Annoying.
I can confirm, got the same issue on latest stable and Firefox Beta on Android 15. :frowning:
Thanks for the reports folks, we can reproduce, will look into this shortly.
Same issue on latest stable Firefox
I’m seeing it also
Multiple discourse (including here in meta)
Tested discourse install 3.4.0.beta3-dev
Firefox android 132.0 (Build #2016051567)
Thanks all for your reports. I am reasonably confident we have a fix for this in UX: Fix Android Firefox Mobile reply position by pmusaraj · Pull Request #29751 · discourse/discourse · GitHub, we will merge that shortly once we do some more testing and a review.
Sometime in the last 48 hours it seems to be corrected on 2 sites I run. Here on meta, it appears somewhat corrected.
