Bug when editing badges - Trigger is changed
When editing an existing badge, the Trigger is changed so it always goes back to:
When a user changes trust level
Very annoying for editing lots of badges!
I haven’t been able to repro this, are you able to give me more details, maybe give me a repro from scratch please, or a video?
OK, I use the API to grant forum badges based on what people do on my site https://tardis.guide
So then I added a Badge Query which is impossible to earn to all of those badges, just so the badges don’t show up in the list for ‘granting badges’ - it was clogged up and I never needed them there.
So all my badges contain this SQL:
SELECT id user_id, created_at granted_at
FROM users
WHERE id = -1000
(This is the only way I know of to remove a badge from that dropdown list).
I set the trigger to “updated daily” just because it’s one that works.
But since the update, any time I edit a badge (maybe to change the description or the picture), the trigger value has changed to the first option because when I try to hit submit it says this:
And when I look, yes the trigger has changed to “when a user changes trust level”:
Screenshot 2024-08-28 at 16.34.51
So I change it back to ‘updated daily’ and hit submit and it works.
But then if I simply refresh the page, it will go back to ‘when a user changes trust level’ so I can’t edit it without fixing that again.
Thanks
1 лайк
Will try to look at this tomorrow and see if I can repro with these info, thanks.
I still haven’t been able to reproduce your exact issue, but I suspect this might help:
1 лайк
